My old modem died on Sunday. My ISP sent me a new Motorola which is up and running. Now, my router, the NetGear RangeMax WPN824 v2, is not reading the new modem. What do I need to do?
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings. b. Select Yes for Does Your Internet Connection Require A Login?. c. Select Other on the Internet Service Provider drop down box. d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
I have a rangemax router connecting my home desktop with windows xp to the internet. At random...
(More)
I have a rangemax router connecting my home desktop with windows xp to the internet. At random times I have to login to the router control panel and switch the settings back and forth from "Use Default Address" and "Use Computer MAC Address." Im not sure why it is doing this, but I have to switch at least once a day to get the internet to work. Thanks in advance for any advice.
had no problems with my wireless netgear router til I tried to install a wireless printer. Now...
(More)
had no problems with my wireless netgear router til I tried to install a wireless printer. Now cannot even get online with wireless -- have to hard wire to modum.
Must I buy Best Buy's $250 wireless router? Or is there another
wireless router out there that's...
(More)
wireless router out there that's more reasonable for this little USB
aircard? (Which works great, by the way; by-by WildBlue!). My Rangemax
does not have USB ports in the back. Dah! Thanks in advance!
ceek
Hi i had it working for 4 or 5 months then had a power failure. now it only works when cabled,...
(More)
Hi i had it working for 4 or 5 months then had a power failure. now it only works when cabled, wirless sees the device, but won't connect. I have done the following all systems powered off powered on in order, (modem wait 2 min, then router) pushed the reset button on the router, updated firmware checked all settings (esp radio on) on router. i have 2 wireless devices that don't work anymore an airlink music bridge and an HP laptop. I can even change the ssid name and see it change on the laptop but no connect, no error message. thanks, Tom
