Question about RCA DRC8335
Bad sound on vcr tape
When I replay a recorded tv show the sound snaps and picture skips
    Problem Solver:
  • 7 Answers
You have a dirt video head and may also have to check the alignment. Run a wet cleaning tape through the machine repeatedly until the screen hiss the shows when the cleaning tape is in almost disappears. It is VERY important to let the head dry completely before putting a tape in. Let it dry overnight. If this only happens with one particular tape then the tape is bad.
Posted on Jan 06, 2008
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Older TV works great alone including sound. Cable TV but no box. VCR connected with cables (red,white and yellow)to TV and has worked fine. Playing home recorded VCR tape picture OK but sound is low and...
Very likely the VCR audio head is dirty which will give you muffled or low sound on play. Remove the the top cover & using a piece of non-abrasive cleaning cloth & a head cleaning fluid gently rub the audio head to clean it. The audio stack sits to the right hand side of the deck, it is usually a siler block which will be placed in front of a black roller. The head is on the side of the stack facing toward you, give this area a wipe, try a fresh recording & then replay the new recording to see if the sound has improved.
Aug 16, 2009 | Memorex Televison & Video
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Running my tv throught my vcr but have no picture only sound
You don't say what kind of tv,model,etc. or if the tv tuner is 'solid state', push button, knob type channel changer.
If you REALLY, REALLY have to use the tv through the the signal [antenna, cable box, cable antenna (signal) in vcr RF a blank vhs tape to record, use the RCA jacks[AUDIO & VIDEO] in back of the VCR to INPUT of TV video & audio ( if you have then ) While you are recording, you will be able to see the tv program.
p.s. place the TV\VCR switch to vcr.
Dec 14, 2008 | Televison & Video
Recording problem on VCR
try cleaning the heads in the vcr. also use a new tape at least once a week.
Oct 21, 2008 | Televison & Video
Taping to a VCR post converter hook-up
cant you just turn the channel on your DCB and then record on the vcr?
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
May 30, 2008 | Televison & Video
Playing slp mode picture rolls
the video and control heads are probably dirty. a video cleaning tape might work, otherwise you will need to get a proffessional to clean if for you.
Mar 25, 2008 | Philips Magnavox 20MC4304 20 in....
First, have you doublechecked the video hookup? It sounds like you are using the video/audio inputs to the TV, so make sure you have VCR video out cabled to TV video input, and the TV source/input selection set to that input (video 1 etc.). If this checks out, check for a dirty video head on the VCR, though a dirty head usually results in a blank or blue video display (older VCRs, snow). You could do a process of elimination by hooking VCR to a different TV and see what is displayed then. Lastly, I assume you've tried multiple tapes, just in case a home recorded tape was incorrectly recorded?
Aug 24, 2007 | Panasonic PV-7450 VCR
DVD Player/Video Cassette Recorder
Hi It sounds like possibly there is stray RF getting into your video signal from your DVD/VCR combo to your tv. Check that your cables are ok, but also, if you can, try moving the unit in relation to the tv, if it is underneath, try putting it on top or beside the tv, I've seen the effect you describe be cause by lack of sheilding in both the tv and DVD/VCR, and moving the unit could cure it. Good Luck!
Apr 02, 2007 | Sanyo VWM-900 VHS VCR
RCA DRC8335 Logo
100 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
