its possible you might be a door switch problem...when you try to heat the food,an it dont work ,lift up on the door handle ,see if it starts working...you might need to replace the door switch or switches...
i have tried everything to make it stop but the only thing that works is unplugging it which is a...
(More)
i have tried everything to make it stop but the only thing that works is unplugging it which is a pain to plug it in all the time when i need to use it. can any one help?
We had a recent power failure and now my microwave beeps intermittently and sporadically no matter...
(More)
We had a recent power failure and now my microwave beeps intermittently and sporadically no matter how many times I reset the clock or unplug it.
It still works fine otherwise, but when cleared off or completed its cycle, it beeps retardedly until I cant take it anymore and unplug it again.
Microwave model - DMW753W Danby designer company Problem - As soon as plug the power it's strat...
(More)
Microwave model - DMW753W Danby designer company Problem - As soon as plug the power it's strat automatically (light will be on & rotate of glass plate) . in that case I can't open the door of the oven as it's moving. it does not accept any of the command from the control panel (loke power, reset, cancell , start , stop nothing works) . Danby designer company Problem - As soon as I plug the power it's starts automatically (light will be on & rotating of glass plate) . I such a case I can't open the door of the oven as it's moving; it does not accept any of the command from the control panel (loke power, reset, cancell , start , stop nothing works).
