Question about Canon Optura 20 Mini DV Digital Camcorder
"DV IN" blinking
When I insert the firewire cable, the "DV IN" message on the LCD screen blinks. When the "DV IN" message on the LCD screen is steady the film transfers. When the "DV IN" message blinks, film does not transfer. I bought a new cable, but the message still blinks and film still does not transfer.
  • Anonymous Jan 10, 2008
    I have the same problem with Canon zr 800's.
  • Anonymous Nov 22, 2008
    i have a gl1 with the same issue.  i can record, playback, output to a tv, but
    firewire doesnt work.   any ideas
SOURCE: Archos 605 copying films from DVD to the player
If change the setting of the 605 to "hard disk" then a PC sees the 605 as a hard disc when connected using the usb lead. You can then copy and paste files directly to the 605..
Posted on Mar 05, 2008
SOURCE: Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Posted on May 29, 2008
Bubbabear64
  • 2794 Answers
SOURCE: JVC GR-DVP7 - Video to PC / Firewire Cable ... where can I get one?
Best Buy has a 6 pin to 4 pin firewire cable. You will need some software as well to copy to the hard drive such as Pinnacle Studio if you don't have on already.
Once the cable is plugged in and turned on Studio will detect the camera and run the program.
Posted on Jul 04, 2008
SOURCE: Mini DV tapes transfer to computer
wow, i have the same exact problem. im using a canon too. and i dont have an installation CD or anything, because i baught my camera at a pawn shop. the only thing i can think of is that i might be using the wrong type of fire wire cord? do i need to use a DV fire wire cord? i have no clue.
Posted on Aug 21, 2008
  • 435 Answers
SOURCE: Cannot transfer from camcorder to computer.
make sure you are using 4 pin to 4pin firewire which looks like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Posted on Mar 10, 2009
No sound no screen. power light is steady, NOT blinking, then blinks 18 times and light is steady again. keeps repeating this action..
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 01, 2016 | Vizio E422VA 42-inch Widescreen LCD TV -...
Canon Elurs 100
Have you installed the driver of your camcorder?
Mar 04, 2008 | Canon Optura 20 Mini DV Digital Camcorder
I just bought an i- link cable (4 pin to 4 pin) and I cant capture videos using sony DCR- HC35e in windows vista. How do I fix this?
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer. Open the Windows Movie Maker Application, select the option "Capture" from the File menu and follow the on-screen instruction to transfer the Video to the Computer.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Dec 10, 2009 | Sony Video Cameras
I have a Sony DCR-TRV27E camcorder. For some reason I can't get it to transfer from camcorder to computer. I have been doing this for years, but it has suddenly given up the ghost!! I have tried with...
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Sep 15, 2009 | Sony Handycam DCR-TRV27E Mini DV Digital...
Sony DCR-HC52E connected with Firewire not detected in moviemaker
Sep 15, 2009 | Sony DCR-HC52E Mini DV Camcorder
Uniden Ex18560 series cordless phone
when I have voice mail messages un-checked, it blinks steady. after erasing, it works right
Nov 27, 2008 | Uniden Cordless Phone
DV In flashing when plugged into computer
Dear njfire,
Test or change your cable !!
(Cable is IEEE 1394 and/or Firewire and/or I.Link, 4-4 pin)
Regards
May 19, 2008 | Canon GL2 Mini DV Digital Camcorder
Eject tape message
Mar 04, 2008 | Canon GL1 Mini DV Digital Camcorder
Im having problems getting my modem to get online. The light wont come on. All but the online light come on. The online light blinks then all the lights go off except the power light, and the receive...
Your modem is not synching. It could be a number of possibilities, and you're going to have to do some troubleshooting to narrow it down.
  • Verify that your AC, Cat 5, & ethernet cables are connected securly
  • Verify that your modem is not in "standby" mode
  • Power cycle your modem
  • Try a different cable outlet
  • Call your ISP to make sure your modem is provisioned and your service is set up for cable internet.
Nov 06, 2007 | Arris SURFboard SB5120 Modem
Canon Optura 20 Mini DV Digital Camcorder Logo
215 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
