Minolta EP4000/5000 CS/PRO Copier
Problem for Minolta EP4000/5000 CS/PRO Copier
What does code CO500 means
By tdtsoutreaci on Nov 05, 2009
what does code CO500 means
Solution #1
posted on Nov 08, 2009
Not Rated)
copydoki
Rank: Wiz  Minolta Office Equipment  Expert
Rating: 80%, 120 votes
Fuser unit malfunction code.Check the fuser unit parts:heater lamp continuity,thermofuse and thermostat,clean ar change.Enter in the service mode Stop -0-stop-1 open the front door,push the reset service buton (located in the up left side,open the windows),close the front door,and get started.
Was this helpful?
Yes
No
Popular Solutions for Minolta EP4000/5000 CS/PRO
Questions and Unsolved Problems for Minolta EP4000/5000 CS/PRO
Do you recommend Minolta EP4000/5000 CS/PRO Copier?
Answer
Answer
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is... (More)
Answer
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this... (More)
Answer
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black... (More)
Answer
canon ir 1630 copier system erroe E245
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Minolta EP4000/5000 CS/PRO...:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
