I accidentally pressed the 2nd button and then the left side arrow button and now I have this black grid on my screen that I cant figure out how to get rid of if I tilt the screen I can see what I'm trying to type but otherwise not at all.
Displaying the grid on the screen is a graphing option accessed through the command GridOn. To turn the grid off, press [2nd][ZOOM] (FORMAT). Use down arrow to reach the 3rd line. Highlight GridOff and press [ENTER]. Press Graph to return to the graph screen.
How you activated the GridOn command by a single press of a button is a prowess. I wish you could teach me this legerdemain.
Hope it helps.
Was this helpful?
Yes
No
Popular Solutions for Texas Instruments TI-83 Plus
Similar problem. I took it apart because it was not working at all (Cursor froze up) Circuit Board...
(More)
Similar problem. I took it apart because it was not working at all (Cursor froze up) Circuit Board was corroded. I cleaned it up, put it back together and everything worked except for the bottom two rows. (can't really tell, but looks like two small circuits are burnt. Has anyone else seen anything similar? Can this be fixed?
Display on TI-83 Plus shows lines (like equals sign rotated 90 degrees) in the top rightmost...
(More)
Display on TI-83 Plus shows lines (like equals sign rotated 90 degrees) in the top rightmost character postion. When you press enter multiple times (moves cursor to bottom of screen), the screen fills up with these vertically oriented equal signs in all the character positions - like a bunch of 11's in each character position. There are distinct gaps between columns and rows (i.e. not continuous lines from top to bottom). The rightmost column's characters appears to have something else displayed in that column in addition to the "equals". Installed fresh batteries, reset calculator - still same result. Thoughts?
over a 10 year term. The loan is amortized at 7.8% with monthly payments of $162.50. After 10 years...
(More)
over a 10 year term. The loan is amortized at 7.8% with monthly payments of $162.50. After 10 years making monthy payments of $162.50 at 7.8% compunded monthly at the end of each compounding period, with the FV be zero? Use the TVM Solver to calculate the FV. Round to the nearest cent.
