Our whirlpool duet dryer randomly beeps displaying the 'CONTROL LOCK' light and will not reset by holding the button. We unplug it and leave it for extended periods and struggle to get it to eventually run. Today it began beeping on it is own (had not been run for a day) and then locked itself. After unplugging and pressing a series of buttons half of the display lights were on. Repeatedly unplugging and resetting finally enabled the machine. What is wrong with this machine?
My dryer knob gets stuck. The dryer will run for hours, once for 8 when I was gone one day. It stays...
(More)
My dryer knob gets stuck. The dryer will run for hours, once for 8 when I was gone one day. It stays in the same spot, not rotating at all. How do I fix this?
Whirlpool dyer modle # GEW9868KL0 will not work, have replaced the board but still nothing. We have...
(More)
Whirlpool dyer modle # GEW9868KL0 will not work, have replaced the board but still nothing. We have correct voltage, but none of the controls work. HELP
Hi my in-laws have a whirlpool LGP6848AWO gas dryer that does not run. The drum motor does turn on...
(More)
Hi my in-laws have a whirlpool LGP6848AWO gas dryer that does not run. The drum motor does turn on and the gas flame does not fire up. It basically does nothing, however, I can hear the timer running and I can hear the start relay energize or click when I hit it and I can hear that the timer stops and the start relay de-energize when I open the door. I've check input voltages, voltage across the start relay seems and across the thermo switches 120vac. Btw the buzzer (part of the tan wire system) seems dead, yet could be normal. Otherwise everything seems to check out. The motor has a block on it with five wires and I do have 120v, yet not sure where it should be. It's difficult to work on, since the front panel also holds the drum in place to run, so I pulled the belt, yet it's still not all that easy. Since its 17 years old, I'm inclined to tell them to get a new one, of course my wife wants me to fix it for them. Any ideas?
the dryer will not start when you push the button to put the dryer on nothing happens even the light...
(More)
the dryer will not start when you push the button to put the dryer on nothing happens even the light in the dryer is off
my dryer has an E-2 code I just replace the theremo fuse because it was completly dead b4 but you...
(More)
my dryer has an E-2 code I just replace the theremo fuse because it was completly dead b4 but you all sent the wrong size fuse but I installed it with an extra hole
