I bought a HP Deskjet F4280 printer in Belgium (Europe) and I bought replacement cartridges in United States (HP cartridges which are to be used with printer F4280) but when i put them in i get an incompatible message
Yes that is how hp Manufactures its printers you will not be able to use the cartridges of Different country There is a Process called Reagionalisation after which you can use the cartriges ....
You need to get in touch with the HP TOTAL Care for the respective country and get this fixed or else you will not be able to use it
the paper feeder makes a loud clicking sound and the feed is somewhat violent and the paper is...
(More)
the paper feeder makes a loud clicking sound and the feed is somewhat violent and the paper is immediately jammed... what is most likely the problem?
cant install hp printer f4280 on windows seven,tried to run on compatibility mode win xp and win...
(More)
cant install hp printer f4280 on windows seven,tried to run on compatibility mode win xp and win visa still unable to run program/it says error on installing..
Hello, I have a HP deskjet F4280, the scanner doesn't always work fine, sometimes I only got half of...
(More)
Hello, I have a HP deskjet F4280, the scanner doesn't always work fine, sometimes I only got half of page or part of the page scanned, and the orginal text/pictures sometimes becomes smaller or larger than the origal one. I'm using Windows XP SP2 on the system which connects to the printer.
Problem printing with HP Deskjet F4280, keeps displaying in the box next to start/copy buttons and...
(More)
Problem printing with HP Deskjet F4280, keeps displaying in the box next to start/copy buttons and Resume light keeps flashing and paper is being pulled in and out and not feeding properly please help?
