Question about Abit IC7-G Motherboard
Monitor wont come out of standby
The PC was working correctly, than the other day i was upgrading windows and i lost power, when i rebooted it jus stays in standby, i can see the fans and hear my drives working but the monitor stays in standby, there are no sounds(beeps) when i boot it up, ive checked the monitor it works on other pcs, checked all the wiring,if it worked before why wont it work now? i had reformatted the HD and i dont even think i got to reinstall windows before i lost power...please help!
  • djswain22 Jan 08, 2008
    ive tried another graphics card and nothing...it has to be something minor,,,
  • 27 Answers
You got two outlooks, a fried motherboard or a fried component. If you have integrated graphics then its probably your motherboard, if you have your own, separate graphics card installed then it could have to do with your graphics card.
Google is your friend. It might not be damaged hardware, just some bug.
Posted on Jan 05, 2008
Boot performance monitoring error
>> Tired to reboot several times and still no video.
>> Waited until the next day and the video was working.
>> Very strange.
Sounds like overheating, either inside the monitor, or on the video-card, or inside the computer.
When it happens again, disconnect the data-cable from monitor from the desktop computer, and connect the data-cable to a laptop computer.
If the monitor works, then it's not the monitor that is the problem.
Also, when it happens again, have another monitor, and connect it, to see if the other monitor works, or if the video-card cannot "drive" either monitor.
Apr 05, 2010 | Computers & Internet
Asus k8v-vm wont resume from standby.
get into the bios and change the setting to start from any key save yes and ok -esc
Jul 04, 2017 | ASUS K8V-VM Motherboard
Please can anyone help me i have recently upgraded my monitor from a xerox 19'' to a samsung 23'' syncmaster now with the monitor in standby i turn on my acer t180 and the green light in the on button...
I assume you are running windows. First off you need to boot into safe mode by pressing F5 repeatedly as soon as you start your computer. Select the option for safe mode. Once you are in then you need to go to the device manager. Click on the run option on your start button then type compmgmt.msc. Click on device manager on the left side. Then click on display adapters, select your graphics card by double clicking on it. Select the driver tab and uninstall the device. Once you do this reboot with the new monitor plugged in. The operating system should install plug and play hardware automatically. Then you can install the software afterwards once you logon on. Special note: you might have to do this with the old monitor first. Once you uninstall the display driver turn your machine off and connect the new monitor. I hope this helps.
Mar 03, 2009 | Computers & Internet
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Boot failure after upgrading bios asus p4xp-x
You have accidently corrupt mother board BIOS,you have to replace it ...no other choice...
Dec 10, 2008 | ASUS P4XP-X Motherboard
Windows XP Pro 64-bit intermittantly wont come out of 'Sleep' mode or waken
Try turning off, and unplugging the monitor.
then replace the cable between monitor and pc.
if you still get no action, i,d suggest looking at the graphics card.
if it,s a pci card, try it in a different slot on the motherboard.
if it,s agp try an alternative card, if it,s onboard, try adding an additional card to the system, to see if that brings the monitor out of standby.
Mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
Monitor lives its own life ;) Turnes off and on in random moments
It sounds like there's a problem in the power supply or inverter section and it's just teetering on the edge of failure. The disruption of the signal is apparently just enough to kick it over the cliff until it's reset. Sooner or later, it'll need some help, like connections, capacitors, output transistors, capacitors, transformers. Those are the most common failures in these. I think you'll see it get worse
Jan 25, 2007 | Dell E173FP 17" LCD Monitor
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
Abit IC7-G Motherboard Logo
133 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
