Home | Motherboards | My wpn111 wireless
Motherboards
Problem for Motherboards
Generic problem for all Motherboards
My wpn111 wireless
By 9930 on Nov 05, 2009
my wpn111 wireless adaptor keep dropping my router signal
Solution #1
posted on Nov 11, 2009
Not Rated)
fredtmccoyjr
Rank: Wiz
Rating: 84%, 90 votes
There is very little you can do about this. You may not like that answer, and I am sorry for the trouble, but there are things you can try.
First, lets understand that wireless is a radio signal, much like a cordless phone. The handset has to be able to communicate with the base on a phone, and, the wifi pc's have to be able to communicate with the router. Some phones and routers (sadly) use the same frequency range, 2.4 ghz. If you have a cordless phone that operates on 2.4 ghz, or if your neighbors have one, then whenever they get a phone call, wifi goes bye bye. What can you do?
1. Upgrade your phone to a wifi friendly one, with a 2.4 ghz offset range (so that the bands are close, but not so close to cause interference) or get another frequency phone.
2. Change the frequency of the router to level 1. Usually they are AUTO or level 6. Level 1 is a low frequency, and lower frequencies usually give slower, but more reliable performance. You can choose between 1 and 11. try all frequencies to see which one gives less trouble.
3. place the router in a more centered location in the home, off the floor. Remember, this is radio. Radio antennas go into the air to receive signal, and your router is no different. A router stuck in the corner of the basement may give poor performance, while a router in the center of the home should service the home easily.
4. upgrade your wifi. Choose the wireless N router and adapters for your machines. they have better capabilities and less interference.
I hope this gives you insight into the issue. Wireless is at the mercy of its environment. Building structures, signal interference, power lines, atmospheric issues, and cordless phones can play a factor in your reception. its just like taking a portable tv thru the house and having to move the antenna around to try to get better signal. Good Luck.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
my h1000e takes long to shut down?what could be the cause of this and how do i solve this problem?
Answer
Need to remove back panel of Easynote SW51-120 - undid all the screws and its not coming off.
Answer
cannot get microphone controls to work, with either microsoft windows media sound, or realtek. How... (More)
Answer
my computer is slow pleas help .its frequency switch is dis mis pleas help me .and my computer fast
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motherboards:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14685
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
