ASUS P4V8X-X MOTHERBOARD VIAP4X533/PRESCOTT/A/L
Problem for ASUS P4V8X-X MOTHERBOARD VIAP4X533/PRESCOTT/A/L...
No power, no beeps, blank screen
By adonis_dion on Nov 05, 2009
just standby led nothing more!
Solution #1
posted on Nov 06, 2009
Not Rated)
mbase213
Rank: Guru  ASUS Computer Components  Expert
Rating: 91%, 231 votes
Hi adonis_dion,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Was this helpful?
Yes
No
Popular Solutions for ASUS P4V8X-X MOTHERBOARD
Questions and Unsolved Problems for ASUS P4V8X-X MOTHERBOARD
Do you recommend ASUS P4V8X-X MOTHERBOARD VIAP4X533/PRESCOTT/A/L (MTHP4V8XX)?
Answer
Answer
my front usb not working
Answer
looking for driver & manaul of motherboard foxconn 865m02 ver 1.0 .
Answer
Windows driver problem code 43 in the integrated intel gm965 graphic accelerator. I already install... (More)
Answer
Hi, please help me, my motherboard P4V8X-X BIOS broken, in the monitor showed file P4V8X-X.ROM to... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
