I replaced cartridges ( all 6) but when power up I get ink fault? also I can not load the cd on my computer, half way thru last step and I get error 1327
Comments:
Nov 06, 2009
- Thanks,
I did buy at office max , all new HP packages.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem.Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Comments:
Nov 06, 2009
- Thanks for responding.
Since they are factory new cartridges, they are under a warranty. I suggest that you can contact HP and find out how they want to go about repairing the printer their products leaked into.
Don
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart C6180 All-In-One
My printer stop printing. I was in the middle of printing picture when my printer stop printing. I...
(More)
My printer stop printing. I was in the middle of printing picture when my printer stop printing. I had to make some adjustment,but don't remember what I did?
When trying to print a document from InDesign CS4, the following error message appears: the process...
(More)
When trying to print a document from InDesign CS4, the following error message appears: the process pstopdffilter stopped unexpectedly with status 1. Unable to proceed with printing process. Printer is HP Photosmart C6180 A-I-O
how do i fix my printer when i pressed the power button and it says shut down but it doesn't shut...
(More)
how do i fix my printer when i pressed the power button and it says shut down but it doesn't shut down
having problems with outlets inside the house no current on then, but main circuit breakers are Ok,...
(More)
having problems with outlets inside the house no current on then, but main circuit breakers are Ok, have current coming out from black wire.
