Question about OKI MICROLINE 591 Matrix Printer
OKI MICROLINE 591
My printer will only print one page in line and then does not adjust correctly for the next page how do I get it to continually print page after page with out having it mis feed. where it then prints on to the second page and splits the information.
  • OKI Master
  • 1,113 Answers
You need to set and store paper size, width etc in printers internal menu and on print driver on pc.
See Oki manual for printer settings its written on the front of the machine i think menu and set power on, then print to see settings then read manual...
Posted on Jan 05, 2008
My OKI 591 is only printing going one direction, not backwards and forwards like before so it's very very slow. Is there a setting that causes this? Thank you
Usually when this printer prints in HIGH QUALITY, it will only print one way, to avoid misalignment issues between the one pass one way and the next pass coming from the opposite direction.
If I am right, lowering the quality of your print to "normal" or "draft" should give you back the "2-way printing"
Apr 01, 2010 | OKI MICROLINE 591 Matrix Printer
Changing default settings
it's in the print settings..open up your print manager, and you'll see a button..for that..my profile has contact info if this doesn't get you there.
Mar 07, 2008 | OKI MICROLINE 591 Matrix Printer
How i can copy the custom paper size for oki 591 to other computer
you can not copy the custom paper size to other computer ....you ca nconfigure same paper size in other computer..........
  1. open printers and faxes
  2. From the File menu select "Server Properties" (Print server properties)
  3. Forms tab
  4. Click "Create a New Form" and add information that you want
  5. Click OK
Oct 08, 2009 | OKI MICROLINE 591 Matrix Printer
OKI Microline 591 prints extra page of paper everytime
There is a setting on most printers to print a separator page at the end of print jobs. You can check the settings of your printer by going to the control panel and clicking on printers. Select your printer, right click and go into properties. The setting for this is usually located in the advanced settings. See if the printer is set up to print a separator page, if it is, uncheck it, press apply/ok button and close out printer window.
Jul 10, 2009 | OKI MICROLINE 591 Matrix Printer
Printing gibberish then feeding several lines, printing gibberish
If text did not line up as planned, your TOF ( top of forms adjustment ) isn't correct. Just correct it using the button on the panel. If after printing 1 page or so and then it begins to go out of place, most probably you hv set the page lenght incorrectly. To correct, enter the MENU on the panel and set the correct page length.
Lastly if printing garbage, most probably you have selected the wrong emulation on the MENU. Correct by entering MENU mode ( press ' SHIFT+MENU ' button together ) and select the correct emulation.
Hope this helps.
KM HOO
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Rolling halfway down the page
is the form tear off on?
if it is try changing it to off
Dec 03, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Help!! Troubleshooting
First thing to try is turning the printer off and back on again. If it still continues, replace the printer cable.
Jun 16, 2008 | OKI MICROLINE 591 Matrix Printer
Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Jan 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Page advance problem
print out your menu of the printer and load the IBM Proprinter driver in windows ,your printer default driver is IBM Proprinter this will sort out the problem.you have probably loaded a OKI driver while the printer is set for IBM.Hope this helps.
Dezzi
Oct 16, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 591 Matrix Printer Logo
381 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
