Casio G-Shock GW300CA-1V Wrist Watch
Casio GW300 (2608) battery replacement
shared by 5 users
posted by barfoed on Jan 04, 2008
My Casio watch (subject) does not recharge. It will shows a blank face.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Posted by KingOfQueens on Sep 04, 2008
Yeup! I have the same watch and I had the battery replaced. Now it shuts off after about an hour of use and resets. The screen goes blank and then it will turn on when ever it decides to wake up and then the time is totally wrong. It worked great for about 2 years. As for paying the company $65.00 to fix it... And the Watch brand new went for $79.00 at Wal-Mart... Well at that price, I'll use it for target practice and go by a Timex Atomic Watch for about $20 and let them replace the battery every year or so for less than $5.00 and not have to deal with the hassle of something that continually malfunctions and causes me irritation. Much cheaper, and more dependable!
Posted by cy_thespy on Jun 23, 2008
the battery of my casio 2608 g-shock too ran out. i think casio is blatantly misrepresenting its watch as solar powered. it may be technically accurate but as a consumer, i take it to mean that it recharges the battery. so i sent my watch in to casio's california service center called Time Machine. it took them 6 weeks to replace the battery and charged me $65. i think casio should be investigated for false claims or the subject of a class-action suit.
Posted by Guest on Feb 11, 2008
me too. anybody know how to get it to hold a charge? I left mine in the sun for 4 days and the battery has only lasted one day after that
Posted by plantman1 on Jan 05, 2008
Me too. Mine will charge if left in the sun, but loses it's charge in about 1 day
Best Solution
posted on Nov 05, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have a casio GW300 (2608) and it needs a battery....I checked Radio Shack They said they stocked the Battery.....Heheh....They DON'T.....Their battery is the wrong one....Only the Panasonic 1616 will work. Radio Shack didn't even know about the "capacitor battery"......Beware !!!
Joe Clack, Albuquerque NM 87107
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Casio GW300 (2608) battery replacement:
I don't want to Accept this solution
Solution #2
posted on Nov 04, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
do a google search for 2608 pdf manual... it is in there... just did it a few days ago.
Thank You!
Solution #3
posted on Feb 14, 2008
Not Rated (0)
robotek
Rank:Guru Guru
Rating: 90%, 684 votes
Hey all. The charge provided by the solar cells on the watch only really extend the life of the battery. The total run time of a battery depends on how the watch is used... backlight requirements etc. The battery will be depleted and need to be replaced.
Here is a site that has good instructions on how to change the battery in your G-Shock watch.
http://forums.watchuseek.com/showthread.php?t=20217
If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
regards
Graeme
Comment posted on Feb 14, 2008
But then the instructions I have provided you may not spply to you if you have a "solar"powered watch where a special type of rechargeable battery is used. Even rechargeable batteries dont last for ever and have a finite number of charge/discharge cycles. If your watch does not appear to be charging, Casio have explicit instructions on how to bets generate a charge from the sun. If attempts to charge fail... it is probable that your "rechargeable" battery is failing and will need to be taken to a Casio agent for replacement.
a manual to check for this series of watch
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2931.pdf
Thank You!
Can you Help with these Watches problems?
I am replacing the bat in the casio 3319-AQ-160 and there...
How do I change time on Casio g shock gw300?
can anyone help me figure out how to change the time and...
i need the instructions.
Hi, I saw your comment about the G-shocks actually not...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
