Question about GE DWXR483EBCC Electric Dryer
GE Electric Dryer
Our GE electric dryer was not drying. We took off the inside back panel and cleaned all the lint off that accumulated. Now we cannot line up the three screws that attach the round plate to the back of the dryer. Model # DWXR483EBEBZWW Thank You
  • 90 Answers
That is one thing I have learned, don't take anything apart that you dont need apart. Clean with shop vac-it will suck it out.
Posted on Jan 06, 2008
How do I clean lint from inside GE Harmony Profile Dryer?
You have to remove the panel. The assume the lint filter works better then they usually do and do not make it easy to open up and clean inside. You may have to open it from the back side which does open up to allow repairs, etc.
Aug 12, 2014 | GE Profile Harmony DPGT750ECPL 7.3 Cu. Ft....
Tip
How to Fix Dryer Lint Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Vacuum cleaner</span> </li> <li> <span>Screwdriver</span> </li> <li> <span>Electric leaf blower</span> </li></ul> <ol> <li> Remove the lint trap from the dryer and peel off the accumulated fuzz.<br /> </li> <li> Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.<br /> </li> <li> Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.<br /> </li> <li> Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.<br /> </li> <li> Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.<br /> </li></ol>
on Jan 04, 2011 | Dryers
My dryer is smoking and making a noise
This is not good and should be disconnected from power source until problem resolved. It sounds like an accumulation of lint in the dryer base, where motor / belt compartment are located. Vacuuming all the lint from inside the cabinet will reduce the risk of a lint fire. Cleaning the exhaust / vent hose all the way through to the outside of building will allow better air flow. I have used a leaf blower to do this. Disconnect the dryer hose from the back of the dryer, and insert the leaf blower nozzle. Secure hose to leaf blower nozzle as best you can so it is air tight. Switch on the leaf blower for half a minute or so. Any accumulated lint in the dryer vent line will be discharged to the outside of building. Reconnect dryer hose to dryer and test to see if clothes are now drying faster.
Jan 07, 2014 | Frigidaire GLER341A Electric Dryer
Clothes get caught
Instructions
Remove the lint screen from the GE electric clothes dryer.
Roll the lint from the screen with your hand. If the lint screen is clogged with fabric softener, fill a sink with hot water and add 1 to 2 tsp. dish soap.
Scrub the lint screen with a soft-bristle brush and soapy water. Rinse the lint screen thoroughly and shake off any excess water. Set the lint screen aside to air dry while you clean the dryer exterior.
Dampen a cloth with warm water and wring it out. Wipe over the GE electric dryer exterior to remove any lint, dust or product residue. If the dryer is very dirty, dip the cloth in the soapy water and wipe away any spots.
5
Wipe the GE clothes dryer with a towel to dry. Replace the lint screen when it's completely dry.
Jan 09, 2013 | GE DCVH515EFWW Electric Dryer
Dryer has started to take longer to dry clothes only 3 yrs old, any reason why this could be happening. A load used to dry in roughly 30 minutes now can take up to an hour.
I would check your venting. If your venting is plugged up it will not be able to expel moisture properly causing long dry times. Feel the airflow outside if its not strong then thats your problem. Good luck.
_MJ_
Dec 15, 2010 | Estate EED4100SQ Electric Dryer
Water is running out from beneath the dryer
If you have water leaking from a dryer, then you have a clog in your exhaust ventilation ducting somewhere. If the lint is allowed to accumulate to the point of clogging, the warm moist air condensates inside the dryer and ventilation causing more lint to accumulate due to the moisture. This condition will only get worse and needs to be remedied as soon as possible. Water inside a dryer is a hazard due to the electric components located in the bottom of the unit. This is where your drive motor and heating circuits are located.
I would strongly recommend you try this quick test. Unplug the unit and remove the exhaust vent hose from the back of the dryer and try drying a load as you normally would. If the air flow leaving the exhaust is forceful and warm, then the problem isn't inside the dryer. The problem is with the vent ducting AFTER the dryer. You will need to inspect for kinks or clogs in the hose from the point where it leaves the dryer, all the way to where it exits your home. If the ducting hasn't been cleaned in a while, now might be a good time to do so. Leaving a dryer in a clogged state will eventually cause it to overheat to the point of failure. Not to mention, this creates a fire hazard and a habitat for rodents. Mice love dryer lint.
If the air flow leaving the dryer is weak and cool, you may have an internal clog inside the dryer. Inspect the air blower assembly for clogs or obstructions and clean as necessary. Cleaning the lint screens on dryers isn't always enough. Some lint does get past the screen and can accumulate over time. Periodic inspection and cleaning is recommended. I check mine about every three months.
Always remember to unplug the dryer before servicing the inside of the unit. If you have questions along the way, please let me know. I hope this helps you.
Jun 11, 2009 | Kenmore 62602 Electric Dryer
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Burning smell from dryer
you smell lint heating up,when is the last time you had your lint trap,lint exhaust,and wall lint hole cleaned out,that is your problem(very unsafe could catch on fire inside the dryer,let me know-mike
Apr 10, 2009 | GE DVL223EBWW Electric Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
GE DWXR483EBCC Electric Dryer Logo
160 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
