Question about Maytag MAH8700A Front Load Washer
Strange code Whenever I press either the power or dial to power up the machine it lights up then in about 5 seconds I get a code that looks like an upside down F and a E. If I push the dial twice it will start to fill then code out. I've unplugged it and nothing helps.
  • 1,314 Answers
The code is for a bad thermister on the washers heater its located at the bottom of the outer tub on the left hand side facing the washer if you have a serial number ending in ga througx or ja through jn then reply to me
Posted on Jan 30, 2008
Toshiba 10kg washing machine display error code E7, it can't wash but can spin so what's the problem? Can anyone help please???
try reset the machine's control board. try this step and bear in mind this may working/not working:
- plug in and power on
- press Rinse, Preset and Water Flow simultaneously, keep pressing and release after lights come on.
- wait about 5 second then press Cancel/Off
- unplug about 5 minutes
- plug and power on, test if it works
good luck
Sep 28, 2017 | Washing Machines
I have a Braun Sensor model 3092 with two quirks. The machine brews coffee great, but I'm curious about 1) the strange, pitchy hum and 2) the Calc light stays on despite having cleaned it.
Yes I can under stand this you have done descaleing but you have not done descaleing in the proper way very thing has its sequence let take dolce gusto by pressing for few seconds the power button it will blink in green this means that the machine is now indescaleing mode when you're done you simply press the power of in this case you have told the machine that you want to do descaleing and after this the internal computer is reset to normal this is why you machine is still blinking because it had not been reset
Feb 24, 2016 | Braun Coffee Makers & Espresso Machines
My LG Washer isn't working. The little chime that rings whenever it is turned on happens but then NOTHING else. No lights, no codes, nothing. I spin the dial but there's nothing, no noise and no lights....
the machine has suffered a power failure?push and hold the main power button plus another button together hold both buttons in for about 60 secounds the machine should reset.adrian.
Mar 16, 2011 | LG Washing Machines
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
Machine powers on but will not start wash cycle. d5 error code.
try this, set the dial to "Drain" press the reset button 4 times in 5 seconds, this will reset the computer and if there is anything wrong it will show its self up, I had a simuler issue, by doing what I have put it completly cured it, all has been good ever since
Jun 27, 2010 | Washing Machines
No screen no nutthin'.
Sounds like you may have motherboard issues. it would not be worth the expense to consider repairing this unit.
Jun 14, 2009 | IBM ThinkPad T20 2647 Notebook
Child lock code -5- has appeared.
Here is what worked for me.
Turn left to light on, then off
on/off (light)
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Aug 16, 2008 | Neff U1661 Double circotherm super...
Error code
ok your on the recall list go to and dont use the washer did you get the door open
Jan 30, 2008 | Maytag MAH8700A Front Load Washer
Looking for programing codes
Turn TV on. Press and hold [Code Search] until LED stays lit. Repeatedly press [CH +] until the channel changes. Press [Enter] to save code.
Dec 13, 2007 | Universal Remote Control Remote Control
Maytag MAH8700A Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
