Question about Microsoft Windows XP Home Edition
Startup when switching on my computer when it hits the windows loading screen the loading bar will scroll for a minute then the comp will freeze. i then have to switch off and back on and then it will go on to safemode options. this happens all the time and we can only use safe mode as it always freezes.
Try to check memory if it is ok then try new ones then start. i try it once and it works.
Posted on Feb 04, 2009
    Brigadier General:
  • 6,966 Answers
Possibly 2 reasons:
1. Driver/hardware/software/application problem; or
2. Virus/malware.
You can consider:
1.1 Run in last known good configuration that worked (by pressing F8 to display menu choices prior to Windows boot);
1.2 In safe mode, Start/Run/type "msconfig" minus the quotes, uncheck everything in the Startup tab, reboot;
1.3 In Safe Mode, run your antivirus or run Kaspersky online virus scanner or anything similar;
1.4 Download/install/run AdAware or anything similar;
1.5 Check you Control Panel for devices with yellow or red markings;
1.6 Set your BIOS/CMOS to conservative/default/best performance settings (normally press Del on powering up);
1.8 Check/Clean your hardware: video card, memory, fan/blowers etc;
1.9 Booting without any USB devices plugged in;
Worst case scenario, use a recovery CD that came with your computer or in the absence of that, reinstall your OS using the 2nd "Repair" option.
Hope this be f help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 05, 2008
  • Louie  Role
    Louie Role Jan 05, 2008
    Hi again,
    Missed 1.7 Do a Hard Reset of your motherboard (use CMOS jumper or remove Lithium battery for a couple of minutes).
    Cheers.
Why does my comp. load web pages really slow, it just started this 1 week ago
Make sure to run a thorough virus scan.
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
Nov 22, 2012 | Microsoft Windows XP Home Edition
On startup the comp goes to the windows loading screen the bar runs a min or so and then it goes to a blank screen with the mouse pointer and goes no farther
youll have to re-formatt and re-install OS.You might have an add-on security product if it is a back/white bar this must be disabled,, de-installed first
Sep 10, 2010 | Gateway MT6707 Notebook PC
Its slowing down and i want to reset everything were i could start off fresh
before you reset every thing lets do these steps
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
PS Please Note to leave a positive note.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Slow running laptop
10.Update Windows
PS: Please leave a positive comment
Jul 07, 2010 | Dell Inspiron 700m Notebook
Kindly any one tell me how to reset the bios password in compaq nx6110 notebook. i forget what entered in it.
.if you are using windows xp and you have the disk you can insert the disk and choose repair windows
go thru the steps keep watching the lower left corner of screen after about 15 minutes you will see loading devices . hit Shift f10 . a black text screen will pop up. in this screen type > usrmngr.cpl
hit enter this will allow you to change or remove the password on a xp system
other os systems you will need to remove the DDO
battery to clear the cmos. replace battery after about 2-3 minutes.
that should get you pass the bios passy
Nov 12, 2009 | HP Compaq nx6110 Notebook
Dell D600 won't complete startup. It gets to the Windows XP screen with the blue scrolling bar, and then it freezes. Any ideas?
Blue scrolling bar continues or does that freeze too.
If not you booting with a cd in the drive is the HD light winking at you?
Is your HD fragmented to the point where you have less than 3/4 free space on it?
Aug 02, 2009 | Computers & Internet
Windows XP freezes at startup
Some files can be missing, try to start your computer in SAFE-mode, if it works you can try again, othervise you have to repair you XP-version. Add me david.vk@live.se for more instructions.
Jul 08, 2009 | Microsoft Windows XP Professional SP3 Full...
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
Computer startup and running issues
Hello:
Try to remove the graphic card and then clean with soft clothe and then insert it again and test.
if same problem encounter, you need to replace the video card, since your pc is virus free.
considering the monitor, you need also to change the or test the monitor but its 10% that this a cause of the symptoms.
most probably the graphic card got faulty.
may this help,
melnavz
Sep 03, 2008 | Computers & Internet
Startup
try to do a clean reinstall of windows
if that does not work than when the comp starts up (after the BIOS tests) press F8 (or F5, i dont remember with one is for XP(i presume this is the OS ! if not ..do the same anyway !)) and try selecting VGA mode - the problem might be do to video drivers, or Safe mode ... log in as Administrator, and try to check if the hard drive is ok, if the computers drivers are installed ...etc ...
try these fore now and give more details if is still not loading. ....
Aug 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Microsoft Windows XP Home Edition Logo
88 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
