Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
Blue Tint Solution LG RU-60SZ30 60 in
If someone can find a picture of the guts of this tv or a tech manual I can point out what the problem is with the blue tint that comes across the screen.
  • 2 more comments
  • katana2424 Jan 21, 2008
    i have a blue haze downleft side and along the bottom?
  • mariocapcik Feb 14, 2008
    blue all around a screen collors are turning allmost in black and white
  • 123davey123 Mar 09, 2008
    ru-50sz30 lg lcd has the same problems of the blue coming in from the bottom and changing to the top then sometimes on the sides please help.
  • Anonymous Mar 17, 2008
    We have the same problem!!!
    An electronic technician diagnosed the problem as the "Light Engine " needs to be replaced....approximate cost of parts and labour is $ 1200 plus!!!!!!!
    The technician said this model of LG has this problem and are not going to do anything about it.
    His advise was to buy a new TV from another company, as cost to rtepair this one are prohibitive!!!!!
    Dated January 17, 2008.
Hey ppl i just pulled this update to our problem it is worth a read:
http://www.hdtvmagazine.com/forum/viewtopic.php?t=12685
Posted on Aug 27, 2009
We had the same problem on ours about 2 years ago. Paid to have a new light engine installed. It is now starting to fail. However we did have the unit on for about 12 hours a day everyday for 5 years total. Won't be buying a new light engine this time.
Posted on Sep 08, 2009
Yes yes PLease HELP GETTING REALLY BAD..
can you ....????
Posted on Jan 28, 2008
    Problem Solver:
  • 5 Answers
DO YOU MEAN A WATERMARK PROBLEM
Posted on Jan 13, 2008
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
We had our tv in storage for a year and a half, now we plugged it in and it seems blurry and has a green tint to in.
Tries tv auto or manual convergence adjustment,see if that solved this problems.If still have the same problems.That mean ur tv have a dead convergence board.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead,must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost like $300-$350 for parts and labors.
Feb 14, 2011 | LG RU-60SZ30 60" Rear Projection...
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
Blue tint on sides of picture
Check for any cold solders and do dry soldering on the PCB and try changing the flyback, it looks like the flyback is dying. Try this.
Nov 06, 2008 | LG RU-60SZ30 60" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Lg 52 inch ru-52sz30 has blue tint
Zenith/LG will fix for free up to 7/1/1/2010. Go to LGservice.com and look for rear projection lawsuit info.
Jun 14, 2008 | LG RU-60SZ30 60" Rear Projection...
Picture fads to Blue after a 30 minutes the picture comes back with a blue tint.
yeah you need a tech to adjust the bias of the picture tube if you are lucky that fix it other wise the blue picture tube is bad
Apr 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue tint
We have had our RU-60SZ30 for almost 3 years. After 13 months it did the same thing, LG covered the cost of the part,($3000.00) according to their certified repair center, but they charged us $500.00 for labor. Now today, 15 months later it is doing it again. I just got off the phone with LG and they say "too bad, you're out of warranty" So my TV that I paid $4000.00 for, has gone out twice in less than 36 months and LG says, "Oh well" After searching the web I found a law firm in New York that looks like they are putting together a class action suit regarding our model. Go to WWW.ZLK.COM/ZENITHTV.HTML and fill in the questionaire.
Dec 25, 2006 | LG RU-60SZ30 60" Rear Projection...
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
995 people viewed this question
