Question about Acer Aspire RC500 PC Desktop
TV Tuner Hi, I upgraded my Acer Aspire RC500 PC hard drive to realise that I lost my TV Tuner. As I use the old hard drive as an external hard drive, how can I install the Aspire TV Tuner to my new Hard drive? cheers,
  • herso10 Jan 05, 2008
    Thanks for the answer.
    I have copied 'WFTVFM' folder to C:\Program Files\ in my new HDD. When I click 'WFTV.exe' in this folder, it gives me a message: 'Cannot find any video capture device'. Do you know what it means and how to fix it?
    Which one is the TV Tuner drivers as you mentioned in your response?
  • Anonymous Mar 18, 2014
    new hard drive
    Sergeant:
  • 239 Answers
Open your program files on your old HDD, Find your Tv Tuner drivers in there, Now you can either drag them onto your new hard drive or copy them into the Program files on your new Hard drive. Make sure you have them in you new one and then unhook you old HDD and Open TV tuner Files should self install. Or you could also, If you know the name of the tv tuner model and series go to Add New hardware Icon in your control panel. Do it from there when it wants you to install from a specific place choose that option then the name of the device should be there under the network option, find your device and install it from that location I sure Hope that Helps you out
Posted on Jan 05, 2008
  • bear001 Jan 06, 2008
    Is your camera plugged in when it tells you there in no capture device, Its searching for a camera. Did you use setup files, you should be able to work your camera if all the software is installed, and you cam is plugged in. I am also sorry about tell you that they would be in the network option, It would be under Tv tuner Output. What kind of device are you using tv, cam, ect. I will try to help you some more if I can just give a little more about what you need, I will do my best to do what I can...
I want instal maltimidia controllar how
Please go to the following website and install the Video, audio and TV tuner Driver. This will install the multimedia controller driver you are looking for.
Please don't forget to rate me.
May 10, 2011 | Acer Aspire RC500 PC Desktop
Hello sir im Meraj asrar ahmed from india my problm is my pc acer aspre rc 500 how to tv tuner driver installation i have a drivers help me please
go here : http://www.acer.co.uk/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1g.c2att92=122&ctx1.att21k=1&CRC=2980211862
Jun 15, 2010 | Acer Aspire RC500 PC Desktop
How can i see TV with acer aspire rc 500 where i have not remote control?
you just buy a external tv tuner card.then u can watch the tv in your desktop
thankyou sir...
All the best....
Apr 02, 2010 | Acer Aspire RC500 PC Desktop
Replace hdd in acer aspire rc500
Replacing a hard drive can be time consuming, but you gain knowledge in the process. Is it a newer SATA or SATAII drive or the older IDE drive? They're both pretty easy as long as you set up for an external boot device before you pull it out. We'll have to go more into specifics when I hear from you next.
DaveF1953
Jun 20, 2009 | Acer Computers & Internet
The hdd has failed on my acer rc500 pc.
You can get the drivers from this link: http://drivers.softpedia.com/get/TV-Tuner-Co/Others/Acer-Aspire-RC500-RC900-TV-Tuner-Driver-5131243.shtml. Or chose your OS if required and then download it....................sodeep
Apr 30, 2009 | Acer Aspire RC500 PC Desktop
Upgrade Acer RC500
hi all you have to do is do a bit of research on your pc then see what is upgradable. im sure if you go to the acer website you can find out a bit more about your pc.
Jan 27, 2009 | Acer Aspire RC500 PC Desktop
Wont boot
DO YOU KNOW WHAT A MOTHERBOARD IS?
IT MIGHT BE A PROBLEM WITH THE CPU....TAKE TO A COMPUTER REPAIR SHOP
IF THESE CONDITIONS WERE FROM THE BEGING, WHY DID YOU NOT TAKE IT BACK TO WHERE YOU BOUGHT IT FROM, IT MIGHT BE DEFECTIVE....ALL CD DRIVES ARE REMOVABLE.....SOME ARE JUST HARDER....
Feb 21, 2008 | Acer Aspire RC500 PC Desktop
Upgrading the Acer Aspire 3050 80GB Hard Drive to something bigger??
Hey there gothicarcher, this is possible to do on your own. you will need to purchase an external drive case, that does exact copies of drives. You can also use this as an external drive when you are done. You could buy a kit for upgrading that also provides the external drive case and the data copying software you will need ( EZ Upgrade kit ). Next cleanup your old harddrive of any unwanted files, and defragment it. Next, mount the new hard drive (ensure it is compatible with your laptop) in the external case. Connect it to the laptop and transfer the data. Next turnoff laptop, remove battery, and following instructions in your manual, open laptop to access the hard drive. Remove it paying extra attention to the way it mounted and any guides that may be attached. Switch guides from old to new and place new hard drive ensuring all connections are made. From here you are good to go. The old harddrive can be mounted in the external case and used. By the way, you can run programs fom an external, but they still use up some admin space on your main hardrive and the speed of the program can be hindered due to the limitations of the connection, causing the occasional stall. Good Luck! p.s. ensure you have the manuals necessary and follow all software recommendations. Lost data can hurt. Back up on disk anything that can't be replaced easily
Jan 29, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire RC500
contact the supper dial provider to send you the driver or the software first if you don't know how to contact them or you lost the information so try to
 go to www.driveragent  and make scan to your driver the web site will tell you if you need the driver and will offer it to you
Oct 23, 2007 | Acer Aspire RC500 PC Desktop
ACER ASPIRE RC500
The driver for the TV Tuner that came with your system is Leadtek Winfast TV2000 Download the driver at this link under the TV Tuner Driver catagory. Hope this works for you http://support.acer-euro.com/drivers/desktop/aspire_rc500.html#driver
Sep 10, 2007 | Acer Aspire RC500 PC Desktop
Acer Aspire RC500 PC Desktop Logo
270 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
