I have an external 500 GB HD. I try to plug it in to my laptop and the light on the front just flashes. The laptop doesn't recognize the HD, and there is no sound coming from the external HD
Comments:
Nov 05, 2009
- It requires external power
Nov 05, 2009
- My other USB devices work fine. Should I still do this?
1. which can be connected dircetly to the USB port and do not need any external power supply to boot. These type of hard drives are similar to those we use in Lap Tops.
2. The second type the one which is similar to those we have in desktops. For these we need external power supply for it to work.
Please let me know which type of HD you are using.
For that make sure usb cable works fine. Try with different usb cable. Also connect usb cable in different usb ports of computer. Right click on my computer then click on proeperty then hardware->device manager. Then click on sign of usb controllers then uniunstall all usb drivers 1 by 1. then restart computer. Then check. If still not recognized then when you power up the computer press F8 key then enter in safe mode. then check. in normal mode again.sometimes harddisk need to start in safe mode . Let me know if you need more assistance. thanks.
I have the same problem thats all over the internet with the wd my book piece of **** has anyone...
(More)
I have the same problem thats all over the internet with the wd my book piece of **** has anyone come up with a solution
my 500 western digital does turn on but when I have it connected ti does not register at all and I...
(More)
my 500 western digital does turn on but when I have it connected ti does not register at all and I hear a clicking sound every few seconds.
When i try to retrieve files from mt my book essential external hard drive i get a message that the...
(More)
When i try to retrieve files from mt my book essential external hard drive i get a message that the file coulnot transfer because it could not find a metadata file
My external hard drive will flash a light for a while then go away and flash again quickly when I...
(More)
My external hard drive will flash a light for a while then go away and flash again quickly when I plug it in. The hard drive will not boot up or load any of my data and my computer will not read the hard drive. what does this mean? And how can I get the hard drive to boot up? It will very rarely after like a month then when it shuts off it wont turn on again.
