Western Digital Caviar GP 1TB Internal Serial ATA Hard Drive
Problem for Western Digital Caviar GP 1TB Internal Serial ATA Hard...
I have a black caviar 1tb hard drive but its only
By kericlark on Nov 05, 2009
i have a black caviar 1tb hard drive but its only showing up as 127gb? ive tried it as internal and have now put it in external caddy but still shows as 127gb drive were as should be 1tb
Comments:
Nov 05, 2009
- hi thanks ive gone into disk manager and found the other 800+gb as an unallocated partion ime now in the process of deleting partition and re formating so hopefully(fingers crossed) itle still be there once finished.
Best Solution
posted on Nov 05, 2009
Very Helpful)
TimHuntJr
Rank: Guru
Rating: 89%, 28 votes
Could be a couple of things 1 the drive could be bad 2 some one could have made a partition on the drive for 127 gb and didn't allocate the rest of the memmory 3 you may have a **** load of bad sectors that may or may not be repairs 4 ya got scamed check the model and do a search on the Internet make sure it's a tv drive to check souloution 2 the eaiest way would be to reformat the whole drive that way you could just make one tb driv or se if you can just allocate the other space without reformating the 127 partition if you need help with reformatting just google it there's numerous documentations on the subject I would tell u but I'm on my iPhone .... A easy way to do it is to run the disk management sofware that windows has it will show your drive and any unallocated space that may be on the drive chech souloutin 3 once you have done 2 and you get your space back hopefully go to start run type cmd and then go to your external drive by typing drive letter: ex F: then enter then type chkdsk/f and let that run it could take a while Soilution 4 slap the guy that sold it to u jk but def try and get ur money back
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
rcalorisian
Rank: Wiz
Rating: 84%, 103 votes
Depending on your computer, if it is older, it may not be able to recognized and more than 127GB. I don't know anything about your computer, which makes this very hard for me to be more accurate. Try using it as an external on another computer and see if that changes things.
Older motherboards (before the massive Memory Increases 500Gb, 1TB) nover planned on it getting that high, so it was not in the programming.
Give that a try.. Sorry I could not be of more help..
Was this helpful?
Yes
No
Solution #3
Not Rated)
raklein62
Rank: Guru
Rating: 85%, 143 votes
May be set in your BIOS so go there and see what it says. You may have to change your OS software too.
Was this helpful?
Yes
No
Solution #4
Not Rated)
lchand1958
Rank: Guru
Rating: 91%, 206 votes
Hi:
Your computer must be a Windows XP computer, as some versions did not support hard drives bigger than 127 gb.
The way to fix it is to use the Western Digital installation CD that came with your hard drive and run their installation program, Data Lifeguard Tools. It will configure your system to recognize the entire drive.
Was this helpful?
Yes
No
Popular Solutions for Western Digital Caviar GP 1TB
Questions and Unsolved Problems for Western Digital Caviar GP 1TB
Do you recommend Western Digital Caviar GP 1TB Internal Serial ATA Hard Drive?
Answer
Answer
deleted files for remote control of my packard bell studio 640. how could i get this sorted
Answer
I was going to open a file on my desktop computer. I had just finished saving the file off of my Mac... (More)
Answer
Hi. I have a LaCie mini hub HD. Maybe 2 years old. But my Mac Mini (G4, running OSX 10.5.8) won't... (More)
Answer
I have a western digital 5oo G external drive. It says that it can't locate the correct path when I... (More)
Answer
i have two PCs, one PC is an AMD 64 and the older one is a Celeron 800 Mhz. I have a seagate 80GB... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drive Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
