Question about Logitech FreePulse Wireless Consumer Headphones
Transmitter plug in poped out and severed the wires. Can I get a replacement transmitter only?
Transmitter sliding plug in popped out and severed the wires. Can I get a replacement transmitter only? mwgottlob@yahoo.com
  • ababy90 Jan 16, 2008
    My transmitter wires seemed to have shorted out and will only produce sound if I put pressure on the transmitter which means I have to hold it constantly which defeats the purpose of the headphones...anyone have any suggestions on how i could fix or replace the transmitter?
  • mrphys Feb 07, 2008
    What I need the the number to call logitech. I can't find it online. Thanks.
Call up logitech if you have had them less than two years, they have a automatic two year warrenty from date or purchase, calla nd they will send a replacement if it is warrented
Posted on Feb 07, 2008
I have the same problem. I don't know where to fix/replace the transmitter.
Posted on Feb 05, 2008
HOW TO REMOVE CIRCUIT BOARD FROM SHURE PGX2/SM58
First, unscrew the cartridge from the top. The round circuit board on top of the transmitter has a cutout on the switch side. Slide a screwdriver through that cutout and pop out the bezel the surrounds the switch. Remove the spring clip that is around the round circuit board and slide out the circuit board.
Apr 26, 2014 | Shure PGX-2 Wireless Handheld Microphone...
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Gray wire from autopage rf-320 car alarm does not send negative trigger
Maybe the transmitter is failing to send the signal. Try changing the battery in the transmitter
Nov 27, 2013 | Vehicle Parts & Accessories
Scosche fm transmitter FMTD8 not playing mp3 files on Flash drive
I bought the fmtd8 scosche transmitter. If you're like me ,you tried to play music from you're cell phone first. That worked just fine. Then I made an sd card with a few hundred songs on it. P.S. I left the audio cable plugged in the the transmitter. The sd card with mp3. songs would not play for anything. After 2 days of trying,I finally decided to unplug the audio cable.. Voila!!!!! Instant sound.
Dec 28, 2012 | Car Audio & Video
How do I sinc my fireplace remote ecs1001-a two button to fireplace
Each transmitter uses a unique security code. It will be necessary to press the LEARN button on the receiver to accept the transmitter security code upon initial use, if batteries are replaced, or if a replacement transmitter is purchased from your dealer or the
factory. In order for the receiver to accept the transmitter security code, be sure the slide button on the receiver is in the REMOTE
position; the receiver will not LEARN if the slide switch is in the ON or OFF position. The LEARN button in located on the front face
of the receiver; inside the small hole labeled LEARN. Using a small screwdriver or end of a paperclip gently press and release
the black LEARN button inside the hole. When you release the LEARN button the receiver will emit an audible "beep". After the
receiver emits the beep press ANY transmitter button and release. The receiver will emit several beeps indicating that the transmitter's code has been accepted into the receiver.
Oct 29, 2012 | Skytech 1001-A Fireplace Remote Control...
I have a Skytech 1001 TH-A thermo remote. Everything was hooked up correctly, but the remote continues not to work. When I turn the remote off, the fireplace comes on and vice versa.
Rhonda, if you have the On/Off/Flame Height Remote Control ... from what you have described (it's working in reverse) someone has wired it backwards to the control valve. With this particular remote, there is a positive and a negative. Reverse the wires that are connected to the gas control valve (at the control valve. Not on the Black Remote Box) and everything should be fine. If you need more help contact Skytech Technical Service @ 888-672-8929 Monday - Friday. They are great people to work with.
Jan 02, 2011 | Skytech 1001-A Fireplace Remote Control...
I LOST MY CHEROKEE CONTROL REMOTE ALARM, I BOUGHT A NEW ONE BUT ITS NOT PROGRAMMED AND I WOULD LIKE TO HAVE SOME HELP TO SOLVE THIS PROBLEM. CAN YOU TELL ME HOW TO PROGRAM IT. IT IS A CHEROKEE LAREDO...
NOTE :PLEASE READ INSTRUCTIONS FULLY BEFORE ATTEMPTING TO PROGRAM TRANSMITTERS.
Program Method A (Customer Program Method)
1. Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
2. Turn ignition to run position. (Allow ignition chimes to stop).
3. Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6. Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
NOTE :(FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP # 6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
7. Repeat steps 5 through 6 to program additional transmitters.
8. Turn ignition to OFF position. Transmitter programming mode v/ill discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
Program Method B (Customer Program Method)
1. Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
2. Turn ignition to the run position (Allow ignition chimes to stop).
3. Using original transmitter, press and hold the [UNLOCK] button on the transmitter for between 4 and 10 seconds.
4. Continue to hold the [UNLOCK] button and press the [PANIC] button. A chime will sound to indicate that the transmitter programming mode has been entered (Allow 3 seconds for chime to sound).
5. Press a button on all transmitters to be programmed into the system including any previously programmed transmitters; a chime will sound when each transmitter has been programmed.
6. Turn the ignition to OFF position to exit the transmitter programming mode.
Program Method C (Dealer Program Method) *Can be used for any type transmitter.
3. Plug DRBIII to vehicle's 1-way data link connector.
4. Follow Service Manual and DRBIII instructions to program transmitters.
Program Method D (For use with AB vehicles not equipped with VTSS only)
1. Locate the dark green program enable wire connected to pin # 1 of the 16-way data link connector under the left side of the instrument panel.
2. Connect the program enable wire terminal to a good ground.
3. Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.
4. Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.
5. Repeat step 4 to program additional transmitter.
6. Disconnect the program enable wire from ground to exit program mode.
7. Turn the ignition to the OFF position and remove the key.
NOTE :REFER TO DAIMLERCHRYSLER MDS2 SYSTEM OR PARTS DEPARTMENT TO OBTAIN THE CORRECT PART NUMBER AND REVISION FOR SPECIFIED VEHICLE.
Dec 18, 2010 | 2002 Jeep Grand Cherokee
How do i change the car key batteries?
Disassembling and assembling hand-held transmitter
NOTE: The top part of the hand-held transmitter is carefully lifted off with the fingernail or a small screwdriver.
Removing key from the bottom part
  1. In order to remove the key from the bottom part, the compression spring in the sliding latch is compressed and held with a small screwdriver.
  1. Lift out the cap and relieve the compression spring.
  2. Push the sliding latch back and pull the key out of the bottom part.
Installation
  1. Insert replacement key into the bottom part.
  2. Install sliding latch and compression spring. Compress and hold compression spring using a small screwdriver.
  3. Insert the cap from above and relieve the compression spring.
  4. Press the top and bottom parts of the hand-held transmitter together firmly.
Nov 12, 2010 | 2003 Porsche Boxster
Alarm wont sound
If your door is protected by a wireless transmitter your problem is most likely a defective switch or a grounded wire from the switch to the transmitter. To determine if the transmitter is working properly pop off the top of transmitter case by using a small blade screwdriver. If you look on the side of the casing you will see a small slot where the screwdriver is placed. Insert the blade of the screwdriver there and twist. The top of the transmitter will release. Inside you will see a small circuit board and battery. If an external switch is used you will also see 2 wires connected to the circuit board which then leads to the swtch. Using a very small screwdriver remove these wires. Now go check system status at your keypad. If the system recognizes the door as open then your problem is a bad switch or pinched wires that are grounding out the switch. If the keypad's status says the door is still closed the problem is in the transmitter. Sometimes these transmitters will be installed using an internal contact/switch.To know if this is the case on your door you will see only the transmitter mounted on or next to the door and a small magnet within a half inch or so on the opposing side. If this is the case your problem again is the internal switch. For replacement of external switches you can try going to a Radio Shack where they offer an assortment. Hope this helps.
Mar 30, 2010 | GE Security Simon 3 Wireless Home Security...
Hampton bay ceiling fan with built-in remote receiver
In case someone else stumbles upon this:
I replaced the remote receiver on one of these fans. jb is right just the top housing that touches the ceiling needs to be removed. Twist it counter clockwise and pull down. You'll see all the wires and the remote receiver. It might not seem like much room to work with, but you can remove the wires and slide the receiver out sideways to replace it or if you can't see the dip switches. Too bad Home Depot is too cheap to even provide instructions when they send you the replacement remove receiver.
May 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Logitech FreePulse Wireless  Consumer Headphones Logo
152 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
