Question about RCA F36645 TV
RCA P52755ST won't turn on.
I have a RCA P52755ST that won't turn on. When I plug it in it makes a whining noise then stops. None of the buttons in front work or the remote. Can anyone help? Thanks
  • 1 more comment
  • ti4u Jan 10, 2008
    The last 3 Characters are LG1
  • thegrayfox Jan 28, 2008
    where is the trasistor ur talking about i have the flyback out but where is the transistor
  • Vista Electronics May 11, 2010
    Please provide last three characters in service # on back for
    accurate part #'s needed...............................T.
Thanks! I will have to call a pro for that unless you think an amatur can do it. I am very mechanically inclined. I'm not afraid to jump in. Could you tell me what fuse is used for the power supply? I went to pop it out to check it and it flew to the front of the cabinet and I can't find it. Thanks again.
Posted on Jan 12, 2008
    Genius:
  • 1,694 Answers
Replace flyback transformer # 232191 AND Horiz out transistor
# 200167 sub 2SD1885 ( use first quality only ) .....both at same
time...........................T.
Posted on Jan 11, 2008
  • Vista Electronics Jan 13, 2008
    If the set makes a whining noise, the AC fuse is ok.....find the
    value on board near fuse clip.....probably 5 amp..........?
    You might want to check with a tech in your neighborhood.....T.
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
Whining noise that stops when you turn the wheel on a 01 chevy prizm
Add some power steering fluid problem solved if not replace power steering pump problem solved.
Apr 18, 2014 | 2001 Chevrolet Prizm
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Whining noise problem and color flickering
Its the color wheel you can get a replacement color wheel for your model and it comes with free instructions on how to index it proprly plus free tech support with on line messageing. heres the link.
http://servicemanuals.vstore.ca/
Jun 18, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
Bad RCA 32 Tube TV
Bad IHVT ( HV transformer ) part # 257805 or ASTI 2078
......................................................T.
Dec 11, 2007 | RCA F32650 32" TV
TV wont come on
some electronic components inside your TV had shorted out! you might be hearing a slight CHIRPING! like the sound of crickets! or maybe whining! the sound migth be coming from the transformer/inductor with a shorted component on its output!
Nov 16, 2007 | RCA F32650 32" TV
Whining noise
The problem i had was when i would play my tv. I had it hooked from my dish to the sony then the tv. When i played a dvd,cd or the tuner it didn't make that noise. It seems my video/audio 2 channel was going bad. I disconnected my rca jacks and used the optical audio connection. The noise stopped and i got a better quality sound.
hope this helps
Oct 16, 2007 | Sony DAV-FC8 System
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
RCA F36645 TV Logo
208 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
