Question about Compaq Presario 5461 (152508-003) PC Desktop
Remove the case
Can you please tell me how to remove the case of the computer? I've not got a manual, and I can't figure it out. Thanks
  • 2 more comments
  • Waverly Jan 05, 2008
    Sorry, this doesn't work...there are "feet" on the bottom, can't see how you could slide the back section down, if that's what you meant.
  • Waverly Jan 06, 2008
    I don't have too much savy with computers, but I did figure out on my own to unscrew the screws...give me some credit, okay!! Seriously, the pics you sent were great; my 5461 Presario doesn't look like that on the back; the case (by that I mean top and both sides) are one piece of metal which has been bent around to form the actual case. The screws are threw the edges of this metal which wraps around to the back about 1/4". There are 2 add'l screws around the fan grill location, but even after removing those, that back panel isn't moving.
  • halecat Mar 13, 2008
    does anyone how to get the front grill off persario 5461
  • oldgringo Aug 27, 2008
    I have exactly the same problem. The screws in the back of the computer fastening the metal, three-sided cover to the back of the computer do not release the cover for removal.
    The metal cover is inserted into the plastic face covering the front and there are two large rubber "feet", one on each of the bottom corners of the rear of the computer. The cover won't budge. There does not appear to be any screws or plastic holders to release the plastic front.
  • 239 Answers
You have to remove the two screws in the Back and then once the screws are out slide the cover back and off, Does that work for you? Let me know if not and I'll send you a how to for the model of yours
Posted on Jan 05, 2008
  • 6 more comments
  • bear001 Jan 05, 2008
    I said the Two screws on the BACK here is a link, To help you out, I am only trying to help people out here every time someone says thanks for trying and don't read what I say hurts my rating, I do this for free. I hope this help you out....">">
    here is a pic then it slides off
    hope this does it for you!! :)
    and please if thats not is let me know I will find out how for you
  • bear001 Jan 06, 2008
    Are you going to give me the fix it or did it not work for you? Could u plz let me know
    That is the model number you gave I don't know why may be it is an older model. Ok this link will work sorry if the other one did not but this one should Help you out, Or Maybe even Newer, But try this link and see if you can find your exact model, I Know it will not come off unless you slide it back, Because it is still stuck in the locks unless you slide I back Firmly, But here Is a good Link You can Check out
    So Sorry
    Copy and paste it in the top address bar if it does not work from here,
How to remove the crankcase from the casing
I assume you have the flywheel and clutch assembly removed and the oil pump moved out of the way?
Jan 10, 2013 | Garden
How to remove sensor from Vivitar 285HV Flash
Pull it straight out from the body. See the instructions on page 9 of the manual.
Oct 22, 2012 | Vivitar Used Replacement Vari Sensor...
I want to remove the hard drive and any other information source from 3 IMac desk top computers before I recycle them. Appreciate any help with this! One is up, running (in case information needed) and...
The following link will walk you thru the process. It will be a piece of cake for you. ;)
Enjoy Ed
Aug 03, 2011 | Apple iMac G5 Desktop
Can anybody tell me the location and/or board identifier of the bios chip on the motherboard for this model. I'm trying to clear out a password (the start-up kind) for a friend of mine, but I've...
some motherboards do have a pin/plug which can remove passworcs i would need to name and model number of the board to find the specifications Power off the computer and make sure that it is unplugged
Open up your computer case. You need physical access to the motherboard to complete this procedure
Find a circular, (mostly) silver metallic object on the motherboard. This is the CMOS battery
CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration. (See Warnings)
Set the battery back into place and power on the computer
The computer should then warn you that the CMOS configuration could not be found. You can either reconfigure it yourself or restore defaults. Restoring the default configuration should be fine.
You will notice that the BIOS password has been cleared and you can boot without it. You may reset the BIOS password to something else by going into the BIOS configuration and setting a new User Password (The Supervisor Password controls access to the BIOS, NOT the computer!)
Hope this helps
Jun 25, 2011 | Computers & Internet
I need to physically open my zd7020us because the metal part where AC adapter connects to went inside the laptop. Does anyone have a repair manual that would tell me what to unscrew and how to repair it?...
Open the access panelUse the following steps to open the case: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a noncarpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
NOTE: If you need product model specific graphics and instructions for opening the PC, search for a support article that specifically pertains to your computer. In the Search field (or Questions or keywords field) at the top of this page, type your computer model number, a space, and the words "opening the case."
  1. Turn off the computer and unplug all cables, except for power, and write down each cable location.
  2. Unplug the power cable and press the Power button.
  3. If possible, move the computer to a clear, flat, stable work surface over an uncarpeted floor.
  4. Remove the panel retaining screws.
  5. Figure 2: Screw locations (your model might look different)c01054110.jpg
  6. Slide off the panel to expose the inside of the computer.
  7. Figure 3: Panel removal (your model might look different)c00309906.gif
  8. If opening the case is difficult, search for a support article that specifically pertains to your computer. In the Search field (or Questions or keywords field) at the top of this page, type your computer model number , a space, and the words "opening the case ."
Jun 07, 2010 | HP Pavilion zd7020US Notebook
Makita ML902 Flashlight how to open case housing to repair
Makita ML902 - great flashlight. but I wanted to upgrade the lamp to LED, and found that the POLARITY was wrong . so i HAD to open the dern thang. the 'special tool' and 'keep in-house' conspiracy had me 'fuming' ... turns out if one were to mark the EXACT spot that the pivot occurs with a felt pen, by drilling a small (sized) hole on each side, (stop as soon as the bit is thru! the shiney material that you stop at are lamp straps) then pressing 2 stiff objects from both sides, the head pops off ! one more screw is uncovered, making it an even 4 screws holding it all together. When i opened the case up, one wire wasn't even soldered to the switch ! aargh. so - swapped polarity, re-soldered the connections, add a bit of fresh solder, re-assemble, voila! I love the 9 volt cases, upgrading everything to 12v and 16v lithium 18650 cells. these old Makita ensembles are great! saw, drill, angle drill, light...
Mar 29, 2010 | Makita Drills
How to change the batteries on the TUF4D1
The front outer rubber cover is removeable. Once you take it off with your fingers, the front unscrews revealing a two piece battery case. Squeeze the top flanges together and lift out, then the battery case shown in the box just lifts out.
Feb 08, 2010 | Energizer Camping, Backpacking & Hiking
Im trying to figure out if my heater core is under the hood or inside the truck under the dash in my 1998 s 10
this under the dash you have to dismantle the board and this is a case where the heter and evaporator air conditioning, good luck fan.thanks
Jan 09, 2010 | 1998 Chevrolet S-10 Pickup
How do you remove the back or open an HPf1903 monitor?
Feb 11, 2009 | HP Pavilion F1703 17" LCD Monitor
Compaq Presario 5461 (152508-003) PC Desktop Logo
71 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
