Question about Filter Queen Majestic Canister Vacuum
Filter Queen Vacuum Just Stopped
I was vacuuming and turned off the vacuum to move it to another outlet and it wouldn't start. No electrical problems here. It is an old reconditioned filter queen canister model 700. Any ideas? I don't have a manual.
  • sawfiler Jan 06, 2008
    How to replace a motor brush?
    David Loewen
  • Anonymous Mar 21, 2014
    which wires hook to which when putting in a new switch
  • 1,673 Answers
Could be a bad switch or a bad cord would be the first things to check.
Posted on Jan 05, 2008
There is no power to my Filter Queen power nozzle. I have cleaned the connection and there is still nothing.
There is an electrical connection at the canister end and again at the beater end. If the beater is not working it is mostly that this is where you problem is. You need to test first to see if there is power at the canister end and then at the beater end. If there is no power at the canister it could be the outlet or something internal. If there is no power at the beater end then that outlet, or the cord could be the problem. If you have power and that end then the problem is likely within the wiring in the beater or in the motor itself
Jan 20, 2015 | Filter Queen Majestic Canister Vacuum
Filter queen vacuum head has no power
More information needed. When you turn on the vacuum do you hear the motor running? Is the problem that there is no suction at the head? Is there suction at the canister when the hose is removed? I would first check to make sure that there is no obstruction in the hose. Have you checked the filters to see if they are clean?
Sep 11, 2014 | Filter Queen Majestic Canister Vacuum
We were told we can add water to the canister instead of using a paper filter. Is there a manual that shows the operation of the Majestic Filter Queen 95x?
This is a DRY vacuum only. Do not put any type of water in your vacuum unless you are cleaning the dirt container only.
Adding water to this machine will cause it to **** the water straight up through the motor and well, water and electricity do not mix.
Nov 11, 2010 | Filter Queen Majestic Canister Vacuum
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
Stopped working
I had a simular probleme with my older model filter queen vac and it turned out to be worn brushes on the motor I simply ordered new ones installed them and then and all it costs was 15.00 usd to canada probably less in U.S. go to this site you'll find all you need there.
Aug 29, 2008 | Filter Queen Majestic Canister Vacuum
Just stopped working
mine has a reset on the power head. alittle red button the back. if it is that old and worn out i would buy a refurbished one on like think i saw one for around $350. just search filter queen and u will find them
Aug 20, 2008 | Filter Queen Majestic Canister Vacuum
Filter ?Queen Majestic Canister Vacuum – Motor
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below: Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Princess III Vacuum
Here is a picture of the dome taken apart, not too hard, take out the 3 screws on top, then the pic should show the rest.
Nov 15, 2007 | Filter Queen Majestic Canister Vacuum
Majestic filter queen not working
could be power switch or power cord, happens alot
Nov 13, 2007 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
355 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
