Motherboards
Generic problem for all Motherboards
Ribbon installition
posted by lang613 on Jan 04, 2008
I have installed a new motherboard nd after lots of troubles go it up and going but now I can not get the ribbon to work right--I have a hard drive-cdrom and cd rewriter--I can us a ribbonfor two hook up and I am fine but not the one that I need to use that has space for 4 hook ups--I have changed the settings on everything with the jumpers--please help--this is a new Asu P5GC-mx mother board
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 06, 2008
Not Rated (0)
postmanfw
Rank:Wiz Wiz
Rating: 85%, 231 votes
Is it ide or sata drives you are using?
Guessing ide as sat have no jumper but best to check :)
Sett all the 3 drives jumpers to "cable select" and then just make sure you hard drive is in the master ide channel and on the end of the cable.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ribbon installition:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
Hi, I assembled a PC comprising of the following...
Motherboards
switching motherboards and the wiring isnt the same. i...
Motherboards
SiS 760 Display Adapter not functioning. I also have...
Jetway (V2MDMP) Motherboard
Good people out there. can you please give me a mobo...
Intel Motherboard
i have not audio and video
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
