our honeywell st6400c thermostat worked fine when installed but now will not run the central heating system on its own - the hot water system works fine - the central heating system only seems to work when the hot water tank is empty and when the hot water function is running- we can't run the central heating independently could this be a problem with the control panel? is this a regular occurence with the ST6400c?
I have a Trol A Temp MST (forced hot air) duct controller connected to HOneywell CM260 dial...
(More)
I have a Trol A Temp MST (forced hot air) duct controller connected to HOneywell CM260 dial thermostat. I purchased Honeywell RTH5100B non-programmable thermostat. Are the two thermostats compatible. I have wires connected to terminals 4 (W), 5(R) & 6(Y) on the dial thermostat.
