Mitshubishi split muh-18nvand inside msh-18nv
After about 2hours running on cool unit stops cooling inside stays running fan only
I am an electrician
if any one can help to direct me to try solve problem will greatly appreciate it
thanks
john
  • 236 Answers
-Start the unit.
-Press EMERGENCY OPERATION switch.3-minute time delay works.Test run operation operates for 30 minutes.
-Check voltage to terminal block of outdoor unit.Is there 12V DC between 2-1?
-If voltage is presenet check the wiring, compressor contactor outdoor fan motor and compressor.
-If no voltage check voltage to terminal block of indoor unit.Is there 12V DC between 2-1?
-If if voltage is present re-connect the continuity of indoor and outdoor unit connection.
-If no voltage replace the indoor electronic control P.C.
board.
-But also check the coil thermistor sensor and room air thermistor if this two is out of range it can cause the tripping of out door unit. It has the resistance of 8 to 10 k ohms at 25 deg c temp.
Posted on Jan 08, 2008
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
Qmark muh won't shut off
I believe these models have a thermal switch on or near the heating element that normally runs the fan until the element has cooled. Similar to your home furnace. If the fan never shuts off this switch is likely bad. IF it takes a long time to shut off then it may be out of calibration. In either case they are non repairable parts and have to be replaced. If the heater is in a high spot resulting in a high ambient temperature it may take a while for the fan to shut down.
Dec 20, 2011 | QMark MUH (0521) Compact Heater
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Air not cold...model MSH-18NV no operating manual for remote . Not sure how to set to cool air when remote reads "I feel..." choices are cool dry or warm but when set on cool 20degrees, luke-warm air blows...
Hi FixYa team. After about 2 hours on the internet I managed to find a PDF file of the operating manual for my air con.
Thankyou for your prompt response. I'll be using your services again!
Jan 11, 2010 | Mitsubishi Heating & Cooling
Cooling not cold
Hi, This is called a split system heat-pump. If it was cooling and stopped and cooled again and now stopped, you need to be sure the outdoor unit is working properly. You can only check certain things as they require special gauges and know how. Make sure the condenser fan is on and reach down where the 2 copper lines are when it is on. Grab hold of the large line which is the suction side and it should be cold enough to condensate. The smaller is the liquid line and should be warm in the cooling mode.If not, listen to see if you can hear the compressor running inside of it. Should hear a humming sound. You can carefully remove the control panel door and feel it to see, but BE CAREFUL! Don't get your hand in the fan blade. Do these checks and get back to me when you do and we can go from there.
Sincerely,
Shastalaker7
Jan 05, 2010 | Heating & Cooling
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Mitsubishi MSH 18NV no heating or cooling
The fact that nothing is coming on indicates that there is possibly a problem with your incomming power supply or wiring to and from the inside evaporator to the outside condenser. If all in good order, suggest you find someone you know who can operate a multimeter and check if there is voltage going to the control board inside the evaporator unit. If there is then almost certainly the control board would need replacement.
Feb 05, 2009 | Mitsubishi MSH09TW Air Conditioner
Mitshubishi 52525
Yes, it is a cool down period. The fan will shut off after a few minutes.
Apr 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Heating & Cooling Logo
832 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
