Question about Panasonic CF-25 166MMX Notebook
    Problem Solver:
  • 6 Answers
If you boot to safe mode, the operating system will load the default vga driver, see if it works in safe mode if it does then check the driver that the monitor is assigned. when you boot to safe mode make sure you use the safemode with networking so you,ll have access to the web to download. go to system properties page then advanced settings/device manager you can view the driver version of the monitor / display adapter and update the drivers or rollback the driver. try running device managers driver update wizard to automatically fix this
Posted on Jan 04, 2008
Gateway computer is stuck in power saving mode.
The Gateway 818GM is a few years old but if - hopefully - the motherboard auto-detects a video card, try removing the MSI MS-8936 video card & swapping over the monitor lead to the other VGA connector fed from the motherboard.
Failing that, if you think it's a faulty video card, they're cheaply available on eBay eg for US$6.70 here:
MSI NVIDIA GeForce MX 4000 MS 8936 64 MB DDR SDRAM AGP 4x 8x Graphics
Feb 21, 2014 | Dell Dimension 3100 PC Desktop
After installing new ATI HD4670 video card on my Gateway zx6810 I boot system hear no beeps computer powers on but screen is black
Is this new video card the only video source on the PC (i.e. there is no other VGA connections on the PC)?
Without knowing the make and model of the PC, I will list the most common issue when replacing the video card in a PC.
1. Connect the monitor to each available VGA connection and boot the computer - to see if any VGA output is working
2. When you find a working VGA output, go into BIOS and change the VIDEO settings to either allow BOTH the onboard and add in video OR allow the add in video only. Save the changes and turn the computer off.
3. Move the video cable to the add in video card, turn the computer on and see if the BIOS is using the new Video card
Nov 03, 2013 | Sapphire ATI RADEON HD 4670, (1 GB) PCI...
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
Disable onboard video card on dx4870 ub318
enter your Bios then Advanced settings there should be an option to turn of onboard graphics or switch to pci..
Dec 27, 2012 | Gateway Computers & Internet
I have a black computer screen
is HDD light is blinking on Computer when it is working ? if so , computer is working and you are having video card issue or something wrong with the monitor.
Feb 27, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Power indicater light is orange instead of green and computer screen is black
This usually indicates no signal from the video card. If this happens at boot and no POST screen display is seen, try checking the connections between the monitor and the video card, there may be a loose cable. Inspect the ends of the cable for bent or damaged pins. Or try swapping the connection cable.
If this is happening after the post screen, then you have a video driver problem, which can be resolved by booting into safe mode, uninstalling your video card drivers and restarting into normal mode.
Hope this helps,
Jan 29, 2010 | Direct Source Distributing IBM G70 (Black)...
Monitor is black...checked all connections..OK. Turned computer off and back on,still no screen. HELP!!!
The first thing I would do if possible is hook up another monitor to the computer to see if that one works. If it does, then your monitor has gone bad. If it doesn't work either, then your video card has gone bad. Did you hear any beeps when you started up your computer? If you did, then this usually means there is something wrong with the video card. Also, sometimes the power button is turned off. Are there any lights lit at all on the monitor and are they green or yellow?
Aug 18, 2009 | Gateway FPD2275W LCD Monitor
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Installed video card and computer won't reboot now
AGP driving control
If you get it wrong, the graphics card won't boot, and you'll be left with a black screen. The only way to remedy this is to temporarily use an old PCI graphics card, change the driving control setting, and then reboot
Dec 14, 2008 | Biostar P4M80-M4 Motherboard
Computers & Internet Logo
182 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
