Kodak ESP 5 Printer
Problem for Kodak ESP 5 Printer
When reinstalling my Kodak ESP 5 software from the
By jjromey5 on Nov 05, 2009
When reinstalling my Kodak ESP 5 software from the original CD, I get a 1304x17x3021026592x error. If I download the latest version of the driver software, I get a 1304x17x425799284x error. I've used the clear utility from the Kodak website, but still the same install errors. Any thoughts?
Solution #1
posted on Nov 06, 2009
Not Rated)
sajid_najmi
Rank: Wiz
Rating: 90%, 12 votes
  1. Make sure that the customer's computer meets the system requirements.
    • WINDOWS XP Operating System: Right-click My Computer, then click Properties.
    • WINDOWS VISTA Operating System: Right-click My Computer, then click Properties.
    • MAC OS: Click the Apple icon and select about this Mac
      NOTE: Home Center Software can only be installed if the minimum system requirements are met.
      Make sure to log the system information into eGain.
  2. Unregister and register the WINDOWS Installer:
    • Select Start > Run.
    • To unregister, type msiexec /unreg, then click OK.
    • To register type msiexec /regserver, then click OK.
  3. Enable services in the WINDOWS Operating System:
    CAUTION: Use caution when performing the following steps. If you modify a service incorrectly, a system crash may occur.
    • Click Start > Run.
    • Type services.msc, then click OK.
    • One at a time, right-click each of the following services, then follow the steps below the list.
      • Background Intelligent Transfer Services
      • Cryptographic Services
      • Remote Procedure Call (RPC) locator
      • Printer Spooler
      • Windows Installer
    • Click Properties.
    • Under the General tab, next to Startup type, select Automatic.
    • Click OK.
    • Repeat these steps for all of the services.
Was this helpful?
Yes
No
Solution #2
posted on Nov 05, 2009
Not Rated)
sijudoniston
Rank: Guru  Computer Hardware  Expert
Rating: 86%, 44 votes
Go to control panel >Add and remove programs and repair Microsoft .Net framework 2.0 and Try to install Kodak software.
Good Luck
Siju.D
Was this helpful?
Yes
No
Popular Solutions for Kodak ESP 5 Printer
Questions and Unsolved Problems for Kodak ESP 5 Printer
Do you recommend Kodak ESP 5 Printer?
Answer
Answer
Kodak esp5 has prominent black line on one side with every scan
Answer
cannot load software keeps freezing gets to 1 min to go then timer goes up to 16 mins then freezes... (More)
Answer
Kodak ESP 5 new cartridges color prints fine black will not print. Only have used Kodak replacement... (More)
Answer
The roller picks up 2 or more paper and is to thick to make it past metal tabs above roller in front... (More)
Answer
i recently replaced the ink cartridges and it is not printer as well as before
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kodak ESP 5 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
