Reddy Heater-170,000 BTU Kerosene Deluxe
Problem for Reddy Heater-170,000 BTU Kerosene Deluxe
Got a 200,000 BTU that won't light.
By jerrysellers on Nov 05, 2009
Replaced the rocker switch and igniter. Igniter glows and I can see the fuel going past the igniter, but it won't fire up.
Solution #1
posted on Nov 06, 2009
Not Rated)
tbugger
Rank: Guru
Rating: 90%, 70 votes
You must start troubleshooting by setting the air pump pressure. Low pump pressure or air leak can cause the problem that you are experiencing. If you check the pressure and it's up to specs, then the nozzle may need replacing.
Troubleshooting tips for ignitor type heaters
http://www.reddyparts.com/HSI_tips.htm
Was this helpful?
Yes
No
Popular Solutions for Reddy Heater-170,000 BTU
Questions and Unsolved Problems for Reddy Heater-170,000 BTU
Do you recommend Reddy Heater-170,000 BTU Kerosene Deluxe?
Answer
Answer
kero heater won't fire. have ignition and fuel from nozzle.
Answer
i have an electric / karosene salamander 175,000 btu reddy heater with thermostat . when i turn it... (More)
Answer
my 170t won't run with cover on but runs fine with it off.
Answer
the only light that comes on when i plug it in is the on off switch and it won't start is it the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Reddy Heater-170,000 BTU...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1229
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
