Question about Microsoft Xbox 360 Console
Error 74 i get an error 74 message
  • 2 more comments
  • Anonymous Jan 05, 2008
    I got a message that said error 74
  • Anonymous Nov 02, 2008
    i will kill you we"re the freakin" poorest family in the world and this is gonna cost one MILLION FREAKING DOLLARS!!!!!!!!!!!!!!!!!! OMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMGOMG
  • SaulDaedalus Feb 23, 2009
    I also got the E74 error its the GPU alright. It can also be coded as 1012, but to be able to do that you need to interpret different flashes when you hold in the sync-up button (small white one) & press the eject button. Im giving MS a realy good moan as its the X-clamps in the Jasper series which causes it, the bloody same thing that causes RROD!!!!
  • SaulDaedalus Mar 02, 2009
    I have the ANA scaler chip problem so Im complaining to MS about it as Im not prepared to be conned out of £60 to repair something that THEY'RE god damn fault
  • 85 Answers
E74 is an error that has two possibilities one is that your AV cable has gone bad. Swap it out and see if that fixs the issue.
If that doesnt work then you need to contact MS, your GPU / Scaler chip has gone bad and MS needs to replace it. There is no fix for this like there is for the red ring error. hope this helps
Posted on Jan 05, 2008
E 74 error message on my xbox 360
thats because that error message means your AV cable has died or the chip inside has cooked, if the error goes away wen you remove the cable its the cable you need to purchase a new one
Oct 26, 2009 | Microsoft Xbox 360 Console
My HP Officejet J6480 all-in-one gives me Cartridge error: Cartridge on right must be replaced. I have changed the cartridge but still get the message.
These types of 'severe' cartridge errors/alert messages (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
Ink Refilling & Cartridge Care Tips - Everything you need to know:
Oct 03, 2009 | HP Office Equipment & Supplies
Cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Sep 21, 2009 | HP Office Equipment & Supplies
I just started getting the error 74 message on x box. help
try this:
Aug 01, 2009 | Microsoft Xbox 360 Console
Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
May 27, 2009 | HP Photosmart C4280 All-in-One InkJet...
HP J8750 Cartridge error
I had this "Cartridge error" problem on my HP J5780 printer. Replaced the cartridge, but still got the same error. Then removed the cartridge and used a cotton swab with a little denatured alcohol, and gently and carefully cleaned the contacts in the printer. Followed this with a dry swab to be sure no alcohol left. Replaced the original cartridge, and have been using it for a week now with no more error message.
Casey K.
Nov 07, 2008 | HP Officejet J5780 All-In-One InkJet...
E 74
hi reza,
Alot of people have this same problem,
E74 is an error prompt when the xbox goes into safe mode.
Te reasons for going into safemode is buntiful.
The best answer is from overheating.
Try resetting the xbox[little white button]
Good luck
Dec 29, 2007 | Microsoft Xbox 360 Console
E 74 error
Try borrowing your friend's HDD and use it on your console and see if it still has the same problem.
Dec 24, 2007 | Microsoft Xbox 360 Console
1 red light: Error E 74
try the x-clamp fix, also try a different av cable as yours can be damaged
Oct 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
126 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
