Question about Nikon FG 35mm SLR Camera
Frame counter-can't shoot
I just bought a nikon fg from ebay.As I was testing it I opened the filmdoor to reset the frame counter and it did.But since I closed it, the frame counter seems not to be able to proceed to the s(start) point.I must say that I'm trying this without a film inside the camera.Thank you!
  • Nikonakias Jan 05, 2008
    First of all thank you very much for replying!You ve been very helpful but I still cant solve the problem.
    There is no foam at the area of this lever.
    The tab is not broken.
    And I dont think its the door.I've even tried to push that lever with a small scewdriver and at the same time to wind the film advance lever.It seemed to move a little but not enough to get to "1" posotion.
    Anything else you could tell me?Plz!
    You think I sould send it back?
    How much would it cost me to fix this at official Nikon service?
  • 667 Answers
Having film in the camera makes no difference for the frame counter to work on this model. The counter is activated by a small tab that protrudes from the top edge of the film door near the hinge.
Locate the area on the camera where that tab meets in the channel along the top of the film compartment. There is a small opening for the lever that engages the drive gear for the counter. The opening may have debris (foam) or the tab may be broken. If neither of these is the case, the film door may be bent slightly and is not pushing the lever in far enough.
It is important for the counter to work on the FG since the metering is not active until the counter reaches '1'. (switch) It blinks 60 &125 in the display otherwise
Posted on Jan 05, 2008
  • Kevin Pettit
    Kevin Pettit Jan 05, 2008
    I don't think Nikon USA will work on the older cameras any more. Parts are no longer available for this model either. An independent repair person may be able to help. For this kind of repair requiring a top cover removal, I would typically charge around 30$, if I could effect repairs.
Nikon fg light meter not working
Light meter only works with the back door shut and the film counter is at frame 1 or more !!, Also if the camera is set at M90 or bulb (B) mode, Meter will not work there ether,
Nov 13, 2013 | Nikon FG 35mm SLR Camera
Picture turn
The frame count is displayed on the panel atop the camera. See page 21 of the manual:
Jul 27, 2013 | Nikon N65 35mm SLR Camera
Nikon FG Shutter Speed Fixed at 1/90
needs repairing at a qualified shop, if you thnk its worth it
Apr 23, 2012 | Nikon FG 35mm SLR Camera
N80 , frame number blinks, won't advance
According to the manual, the only time the frame counter blinks, is when the back is open or partially open when attempting to rewind film. Push on the back to be sure it's properly snapped closed to see if that solves the issue.
Jul 26, 2011 | Nikon N80 35mm SLR Camera
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i...
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Sep 29, 2010 | Nikon F3HP 35mm SLR Camera
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Jul 20, 2008 | Nikon Cameras
Frame Counter Indicator does not go beyond the 26th and 27th Frame
Considering the age of the camera, you probably have a broken indicator gear in the top of the camera. The chances of getting it replaced aren't good. If it still works otherwise, I wouldn't worry about it. Just use 24 exposure film.
Jul 01, 2008 | Nikon FE 35mm SLR Camera
FRame Counter does not move beyond the 26th Frame even in a 36 roll Film
Simple, the film counter unit has plastic gears underneath. the gear position or gear has worned out. simply replace the counter unit and adjust. This can be performed by any local repair shop for less than $100. -James. for further assistance email, go to
Light meter does not turn on
The frame counter must be at '1' for the meter to work on this camera
Dec 13, 2007 | Nikonos V 35mm Point and Shoot Camera
Nikon FG 35mm SLR Camera Logo
333 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
