Yes. You can do it. Part should be $40 or less. Turn off the power to the oven. Remove the oven racks.Unscrew the element screws from the back wall of the oven. Carefully pull the element out. The wires may be short. Remove the wires from the element. Do not let the wires pull back into the oven cavity. Take the element to the appliance parts store and have them match it to the existing element. Attach the wires to the new element,insert the terminals into the opening,replace the mounting screws. Turn on the oven and bake away. P.S. Your model number is not correct.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thankyou for your help I will have a go asap.
" - angierowe200
I do not see why not.
Here is a site in the UK with elements for most electric ovens.
You will however need to get the code number off of the oven it will be EOU6330 but it will be followed by a letter, look for the serial plate, it may be on the back. www.RansomSpares.co.uk/Elements
hello when i turn on the bottom oven nothing happens no neon comes on, made oven on manual setting...
(More)
hello when i turn on the bottom oven nothing happens no neon comes on, made oven on manual setting still does not work top oven and grill is ok just the bottom one thanks andy
top oven & grill working fine but bottom oven does not heat up. red illumination light still...
(More)
TOP OVEN & GRILL WORKING FINE BUT BOTTOM OVEN DOES NOT HEAT UP. RED ILLUMINATION LIGHT STILL WORKS. THANK YOU
hi the door on my electrolux premier oven has locked as if it is in the pyrolytic cycle. i did not...
(More)
hi the door on my electrolux premier oven has locked as if it is in the pyrolytic cycle. i did not put it on, one of my children did so i do not know whether they turned the dial to self clean or not. can you tell me how to unlock it please kind regards carole
