Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Problem for Texas Instruments TI-84 Plus Silver Edition Graphic...
Graphic calculator texas:when i graph any
By bmwthao2110 on Nov 05, 2009
graphic calculator texas:when i graph any function, it always says "invalid dim"
Solution #1
posted on Nov 05, 2009
Somewhat Helpful)
k24674
Rank: Guru  Office Equipment  Expert
Rating: 87%, 734 votes
A previous problem on statistics has turned the statistical graphs ON and that interferes with the graphing of functions.
TurnOff the STATPLOTS by pressing [2nd][STAT PLOT][4:PlotsOFF]. Command echoes on the home screen. Press ENTER. I was going to add to reset all ram just in case.
Make sure you are drawing the right type of graph. To check that press [MODE], scroll down to 4th line to highlight Func and press ENTER, if you are drawing y=f(x) functions. The others are PARametric, POLar, SEQuence.
Hope it helps.
Was this helpful?
Yes
No
Popular Solutions for Texas Instruments TI-84 Plus
Questions and Unsolved Problems for Texas Instruments TI-84 Plus
Do you recommend Texas Instruments TI-84 Plus Silver Edition Graphic Calculator?
Answer
Answer
my gc can't work at all, after i tried to install some necessary applications. where can i get it... (More)
Answer
The Line( command on my TI-84+SE calculator does not erase even though I have the synrtax correct.
Answer
how can you change your language on your ti 84 silver edition calculator in under 4 key strokes
Answer
my calculator memory won't clear, even when i press 2nd and the plus key.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Calculators Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
