Question about Samsung HCN5527W 55" Rear Projection Television
Tv wouldn't turn on
Checked power outlet. remote control does not work either.
  • 61 Answers
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the TV.
Posted on Mar 11, 2009
TV WILL NOT TURN ON
      NOTE: If the TV turns on and off using the POWER button on the TVbut does not respond to the POWER button on the remote control, troubleshoot the remote control. Unplug the TV power cord from the electrical outlet for 30 seconds. Plug the power cord into a known working electrical wall outlet.Aug 15, 2015
      The TV will not turn on or does not have any power. - SONY
      https://us.en.kb.sony.com/.../the-tv-will-not-turn-on-or-does-not-have-any-...
    Feedback
    TV Will Not Turn On - Troubleshooting Help for Finding ...
    ? 2:32
    https://www.youtube.com/watch?v=kEDVc-BXf0I
    May 1, 2014 - Uploaded by ShopJimmy.com
    TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and causes of ...
Jan 14, 2016 | Televison & Video
Tv wont turn on
Is the outlet powered? Try turning set on with own power button? Remote power button? If still nada, then check to see if something is amiss with the power supply section of set. Look for bad caps and diodes.
Oct 07, 2015 | Emerson Used Original BLC320EM9 Remote...
Samsung un46f6300 does not turn on
Does the power on led burn?
If not, check if the power cable is inserted in the wall outlet. Check if the wall outlet has any power, by plugging in a lamp or so. Then check if the power cable is correct inserted in your flat panel TV.
Still no light, perhaps the cable is defect. If you have a power led burning on the TV, try switching it on manually, not by the remote.
To check the remote control, use a smart phone or a digital camera. Hold the front of the remote control in front of the camera lens and while the camera is on, press the on / off button on the remote. Look at the display if from the remote control is coming some light. If not, replace the batteries in the remote control. Or if the remote control is new, perhaps you should put in some batteries?
Jun 02, 2014 | Televison & Video
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
Tv turns itself off every 5 minutes
Please check the Model # of the TV and check if there is any related Firmware/Software update for the TV model.
Please check if the television has a timer option, ensure it is disabled.
Please check the remote controls to see if any of the buttons are stuck that may be interfering with the television.
Please try connecting the TV to different AC wall outlet and check if that helps.
Try resetting the TV and check if that helps.
Unplug the power cord of the television from the AC wall outlet for 60 seconds.
Plug the power cord back into the AC outlet.
Attempt to turn on the television.
Remove all remote controls from the room where the television is located.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service will be required
Jul 17, 2011 | Televison & Video
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
My remote control for my rca combo 20f510td is not ejecting my dvd from the t.v. .... also actually none of the dvd buttons are doing much of anything when I press them, i.e. the play, pause, eject,...
For remote control concerns. You can try to reset your remote control but be shure before you reset your remote your tv should be unplugged from the power outlet. So here are the 4 steps to reset your remote:
1. remove the batteries,
2. press and hold the number 1 button of the remote control, thus draining all the remaining electricity.
3. put the batteries back in.
4. plug the tv on the power outlet then turn the tv on and try the remote control.
Now if these steps do not work check the warranty of the tv and have your remote be replaced if it's under warranty and if not you can try to purchase a universal remote control that supports RCA tv's.
Sep 09, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
No power
If your television has no power, try the following:
1. Check the power cord for breaks, tears, or exposed wires .
2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
3. Go to your fuse box or circuit breaker box and check the fuse or circuit breaker of the circuit your TV is plugged into. Replace the fuse or reset the breaker if necessary.
4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service.
Thank you !!
Jun 04, 2010 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
Samsung HCN5527W 55" Rear Projection Television Logo
103 people viewed this question
Jerry Greenberg
Jerry Greenberg
