GE WSXH208A Front Load Washer
Problem for GE WSXH208A Front Load Washer
During the spin cycle, the drum seems to spin off
By hohnholt on Nov 05, 2009
During the spin cycle, the drum seems to spin off the axis slightly causing a very loud banging noise as it makes contact with other parts of the machine. Is that an easy fix?
Solution #1
posted on Nov 10, 2009
Not Rated)
dhoosack1
Rank: Apprentice
Rating: 0%, 0 votes
Throw the machine Out! You can never fix a machine that is faulty when new. This model should be replaced by GE. It's a LEMON.
Don H.
Was this helpful?
Yes
No
Solution #2
posted on Nov 05, 2009
Not Rated)
reddyanantha
Rank: Wiz
Rating: 84%, 56 votes
its easy please check the shocks which will fixed to the bottom of the drum these should be good in condition and check the floor level and adjust the level if varies.and check the drum holding hooks to check all these please open the back and top cover of the machine
Was this helpful?
Yes
No
Solution #3
Not Rated)
mandlapplian
Rank: Guru  Washers & Dryers  Expert
Rating: 95%, 26 votes
it sounds like you drum support or spider as it is called may be cracked or your bearings are shot the fix is time consuming and will take patience as you dismantle make sure you take note where all parts fit if you are not confident call a reputable repairer cheers
Was this helpful?
Yes
No
Popular Solutions for GE WSXH208A Front Load Washer
Questions and Unsolved Problems for GE WSXH208A Front Load Washer
Do you recommend GE WSXH208A Front Load Washer?
Answer
Answer
washer makes squealing sound when in spin cycle
Answer
the maachine will wash but the spin cycle will not come on, you can manually spin it but, i was... (More)
Answer
washer stops during cycle motor keeps running
Answer
front load washer will not drain and sometimes does not spin
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE WSXH208A Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14857
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
