Question about Canon Elura 85 DV Digital Camcorder
Won't accept minidv tapes
Keeps giving a 'remove the cassette' message. have shut down and reloaded, as well as trying new tapes, etc. owner's manual has no solutions. used only as a deck, for less than 30 hours.
thoughts?
That happened to mine. I had to take the camera back to bestbuy where I bought it and get it fixed. I forget what was wrong with it. Something on the inside got screwed up. I think it was called dubbler or something like that.
Posted on Feb 01, 2008
Error 02 - 574
Main code 2X : Mechanism control system error
574 Failed to detect the T reel FG during search.
This means the take up reel stopped rotating during forward search. It shut down assuming tape was spooling loose into mechanism. Could be just a faulty cassette tape. A common problem is also when labels have been placed in the wrong places on the cassettes, stopping the lid from opening fully and stopping the reel reaching the reel motor drive.Manually eject the tape and try another tape. If the fault continues, have a look for something in the way under the cassette such as post it notes, paper clips, torn labels etc.
Have you had the unit serviced since you got it?
Could be time to get it to a service centre for help.
Aug 06, 2012 | Sony HVR-1500 HDV VCR
Re-Insert the casette problem
sony is notorious for brand specific the same can be said for their mavica series cameras that can use any mini-disc. unfortunately the best solution is to stay with sony tapes
Jul 30, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Cassette will not fully eject open to remove tape and will not play the tape
if you cant pull it off with a pencil or something small.. you can try with a screw driver and lots of patience to open the tape bay...
Dec 29, 2007 | Canon ZR45MC Mini DV Digital Camcorder
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
Canon ZR500 won't close cassette bay
If your camcorder experiences an error, you may be presented with a ?Remove the Cassette? message. There are several reasons that this message may appear, but it is essentially a safety warning that is designed to protect the camcorder and/or tape from damage. The camcorder?s tape drive mechanism is made up of many precision components that, once damaged, may cause further problems if the mechanism continues to operate. When a problem is detected the safety mechanism is activated. The ?Remove the Cassette? warning and the camcorder?s safety mode may be activated by a variety of conditions such as: 1. Condensation is detected ? If condensation is detected by the camcorder, the ?Remove the Cassette? warning may occur. 2. Component failure ? If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder. 3. Sand or grit damage ? The camcorder?s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate. 4. Impact damage ? If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur. 5. Liquid damage ? If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation. 6. Improper videotape insertion ? If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual. 7. Damaged or defective tape ? If a tape becomes damaged, please discontinue its use. Operational Recovery Steps Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps: 1. Eject the videotape Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2. 2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry. If the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com.
Aug 27, 2007 | Canon ZR500 Mini DV Digital Camcorder
Error F03
F03 is a loading mechanism error. look for something obstructing the loading arms in the mechanism - a label from a tape, a piece from a broken cassette, etc.
May 08, 2008 | Panasonic AG-DV2000 Mini DV VCR
Loading a cassette
having the same problem...when I put a new tape in it just ejects it right away!
Apr 17, 2008 | Canon ZR200 Mini DV Digital Camcorder
Camcorder Canon ZR 200
First if you have a very bad tape (miniDV) (hard to turn by your hand) the camera will automatically eject coz it cant load the tape to it. it is not a head problem. It seems that you have a mechanical loading issue here. But try to put new miniDV tape. ANd post here what happen. PS Dont use compress gas to clean it you might put new problem. Please use only the head cleaner tape (MiniDV) if you want to clean the head. Hope this may help you
Aug 13, 2007 | Canon ZR200 Mini DV Digital Camcorder
Canon Elura 85 DV Digital Camcorder Logo
120 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
