Question about RCA P46924 46" Rear Projection Television
TV (RCA model F32705) stuck on one channel
My TV is stuck on ABC. I have no remote for my TV. It broke and i felt I did not need it anymore. Anyway, I change the channel the old fashioned way, I get up and use the button on the tv. As I said earlier my tv is stuck on abc (channel 3 i think). When I change the channel using the buttons on the tv the channel number changes but the tv stays tuned into abc. Does not matter if I use the up or down channel button the result is the same. I have unplugged the tv and disconnected it from the vcr and called the cable company. All have lead me to the problem is with the tv. I need some advice on what to do next. Steve Stuck on CBS
    Problem Solver:
  • 11 Answers
Go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Posted on Feb 08, 2008
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Channel change buttons on the TV set will only go to 44 and 50 I need 03 for converter box.
If you cannot change the rf frequency on the tv set to 03 or 04, there is no way you can get the converter box to work with that set..
Sorry.
Apr 18, 2015 | RCA Televison & Video
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
Need to undo channel sets without remote
this can always be done using the buttons on the tv if there is no menu button sometimes you can hit the volume up and down buttons at the same time and it should be down hill from there. good luck to ya
Nov 23, 2010 | RCA F32705 32" TV
Stuck on 1 channel
Get a cable box from the cable company it will be cheaper than repairing the tuner. Then you use the tuner from the cable box instead.
May 07, 2010 | RCA 27R410T 27" TV
Can't change input to play Xbox without clicker. With tv clicker I could access channel 00, which allowed me to play xbox. now the clicker is broke and I can't access channel 00. can i do this through...
The only way is with the remote. Try to find a GE or RCA universal remote. These remotes are designed around GE and RCA tv's and generally don't have to be programmed. (GE and RCA are both THOMSON made sets). Thanks
Oct 13, 2009 | GE 31GT660 TV
Powers on and off my itself. Changes channels by itself
i had the same problem. i opened the t.v. took out the circuit board to the buttons and broke off the little resistor things to all the buttons. JUST BE CAREFUL NOT TO BREAK THE ONES LEADING TO THE IR LIGHT. if you can find another button board thatd be a better fix. let me know if you do please. anyway put it back together and use the remote from now on and it wont turn itself off anymore. my guess is one of the buttons shorted out or something.
Apr 18, 2009 | RCA TruFlat 27F520T 27" TV
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
Apr 25, 2007 | RCA F32705 32" TV
RCA P46924 46" Rear Projection Television Logo
436 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
