Question about HP OfficeJet 7110 All-In-One Thermal Printer
Hp officejet 7110
Both ink cartridges are full, but neither will print. The paper comes thru like it has printed, but only has very, very faint ink visiable and that is only on the lower portion of the printed line. The upper portion of the line is completely missing.
1st how old are the cartidges ink could be solidified.
2nd did you take the plastic off of the new ink heads?
try runninng clean pint heads from printer control
Posted on Jan 18, 2008
Replaced both print cartridges but print is faded blue
Solution: There are a number of steps you can take to solve this problem (in order of easiest & least expensive first).
1. Make sure you have tried printing a nozzle check and you've carried out all the maintenance tasks that the manual alows (align print head, clean print head etc).
2. Your cartridge may be faulty. Ink cartridges that use non-genuine ink are of variable quality and you use them at your own risk. Even genuine cartridges can expire if used after the expiry date. Bad ink can clog your nozzle. It may be that you have a dried-out ink cartridge - try another one if you have one handy.
3. The print head may need cleaning. There are Canon print head cleaning kits available (use Google top right) or you could try doing this yourself - some people have had success immersing the print head (not the cartridge) in cleaning alcohol, warm water or using compressed air to gently blow through the nozzles.
Apr 30, 2010 | HP OfficeJet 7110 All-In-One Thermal...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Printer prints no ink.
probably you just replaced th "ink" but what you really need to replace is the "PRINTHEADS"
Put new printheads and printer will print like new again.
Sep 13, 2009 | HP OfficeJet 7110 All-In-One Thermal...
I have inserted a new color cartridge to an HP officejet 7110 and the message I now get is replace color cartridge as it is out of date. This stops all printing! Can i by pass this?
On this series you cannot bypass for black and white printing. You will have to replace the colour cartridge, but be wared once you've replaced both if your print heads are also expired their warning will come up next and they cost about $120-$150 per set.
If they're still ok you will be back in business, if the message comes up next stating one of your print heads is expired, buy a full set as the messages only come up after the previous is cleared and they all tend to go on the same day.
Hope this helps.
Chris
May 05, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Trouble printing some colors.
Have you tried performing a head cleaning? Usually running the cleaning process will clear it right up. After cleaning run an alignment to make sure the heads are straight.
You can find the utility in the print driver properties and look for maintanence tab.
Hope this helps
TankMurdock
Apr 24, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Printing and scanning
try replacing the ink cartridges as they may have dried out either from age or the seat where they are stored when not being used is caked with old ink.
May 27, 2008 | HP Officejet 4215v All-in-One Printer
HP Officejet 7100
Check the ink level present in the color cartridge and check whether you have enabled print in grayscale option in HP Director, please disable the option and try to print, if the issue persists replace the color cartridge.
Dec 05, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
143 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
