You may be better looking for alternative versions of your TV, it is unlikely that Tevion is the only version of that set, there may be a code for a different manufacturer which works.
Unfortunately there are probably many of the newer flat panel TVs for which there are no codes yet.
Try _http://www.urcsupport.com
also try codes: 1326 & 0065, they are very commen codes.
Ilo 23" LCD Model V23DLWX-U12; Will power on with a static noise and no picture. After 15sec or...
(More)
Ilo 23" LCD Model V23DLWX-U12; Will power on with a static noise and no picture. After 15sec or so it shuts down. Sometimes, it would turn back on after powering off by remote.
I have an ILO-26HD television set which I purchased 3 years ago. Suddenly the menu and volume...
(More)
I have an ILO-26HD television set which I purchased 3 years ago. Suddenly the menu and volume controls quit working. They do not work either manually from the set itself or via remote. Can you advise?
Where can I buy a power cord for this tv . It will not power on and the green light on the power...
(More)
Where can I buy a power cord for this tv . It will not power on and the green light on the power cord will not cut on.
I have a Zenith Z25A66R went from working fine to it wont turn on. I hear the same noise coming from...
(More)
I have a Zenith Z25A66R went from working fine to it wont turn on. I hear the same noise coming from the Tv when i try to turn it on as it has always made but there is no picture or sound, but power is there. I havent taken the back off yet , dont know what to look for but there is a smell when its power on. In the last month add comcast digital box but it worked fine until yesterday.
the volume buttons and channel buttons will not respond. you can only turn it up or down with a...
(More)
THE VOLUME BUTTONS AND CHANNEL BUTTONS WILL NOT RESPOND. YOU CAN ONLY TURN IT UP OR DOWN WITH A CABLE BOX.
