Question about Lowrance Iway 500c GPS Receiver
My LowranceiWay500C is displaying error message in
I recently updated software to 1.8.0 on my Lowrance iWay500C. Now When I search POIs I get an error message_No items found in Restaurants category
  • docdxn Nov 19, 2009
    Thanks (trewm) for your reply. I have already tried that solution-(4-times). When I re-boot my 500c, that fix (will not load) to populate the POI's.
    I have tried Soft-Reboot/Hard-Reboot also-(still no luck). The 1.4-POI's will not do anything after a successful download.
    I'd like to wipe-out the whole hard-drive and start over but I'm not sure if the downloads are available for such a radical move. (1.8) has a function in Main Menu called-(Transfer Data)-with a dropdown choice of-(Transfer Data Which Way)-(Save or Load).I'm wondering if I can use that to Load the Update somehow?...ANY MORE IDEAS?...(DocDxn)
    New Friend:
This is a known issue with the 1.8 update. The solution is to reload the POI from the 1.4 update. Lowrance have the file to do that here:
http://www.lowrance.com/Products/Automotive/iWAY-500C/Downloads/iWAY-500C-POI-Update/
Posted on Nov 12, 2009
  • trewm Nov 19, 2009
    Your next step would be to contact Lowrance Technical Support. They can be quite helpful.
SOURCE:
Have NAVTEQ Q1-06 in IWAY 500C. Looking for latest update.
Assuming you are interested in the latest Map update, try contacting Panapacific, Although I have not purchased this product, they say they have the iWAY500c and iWAY600c Navteq Map Update Q1-10 v1.7 listed as Part Number: PACCARQ110
Although listed on their website, the product is currently unavailable for purchase online. Contact their customer service department at 1-800-726-2636.
The map update is $74.99 plus shipping and tax.
Apr 25, 2010 | Lowrance Iway 500c GPS Receiver
Lowrance AirMap 600C won't lock on satellites
Reset the AirMap 600:
1. Turn unit off
2. Press and hold PAGES and PWR until you get the "warning, do not rely..." message and then release the buttons.
If it still won't acquire position, install the latest update from http://www.lowrance.com/en/Products/Aviation/AirMap-600C/Downloads/AirMap-600C-Software-Update/.
If it still won't acquire, and it has a clear, unobstructed view of the sky, and the batteries are good, there is a malfunction and it will require service or replacement.
Jul 13, 2009 | Lowrance Iway 500c GPS Receiver
Lowrance globalmap 2400 on/off button stuck, unit tries to turn on then screen is blank, tried wiggling back and forth no luck, should i send it in for repair and where to...live in carroll county, md....
You can try a hard reset:
1. Turn unit off
2. Press and hold ZIN, ZOUT, and PWR until you get the "WARNING, DO NOT RELY..." message.
If that doesn't work, try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it still doesn't work, and you can't get through to Lowrance by phone, try emailing them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
It probably won't be worth repairing the unit. You will be better off putting that money into a current unit which will be much better than the 2400 and probably less expensive than the 2400 was when it was new.
Mar 23, 2009 | Lowrance Globalmap 2400 GPS Receiver
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
GARMIN 260W
Hi It is more important to know how to add POIs. Here is a simple tip:
1. Create some directory especially for download. I use the following one: C:\Garmin_POI_GPS_DATA_TEAM
2. Download and save all CSV and BMP files to that directory. You may create any subdirectory and use it to save POIs for that category.
I use: C:\Garmin_POI_GPS_DATA_TEAM\Restaurants, C:\Garmin_POI_GPS_DATA_TEAM\Petrol etc.
3. Garmin's POI Loader will find all files in these subfolders and will use them to create a category.
Garmin POI Loader will search through the directory C:\Garmin_POI_GPS_DATA_TEAM and will create/transfer all corresponding POIs to your connected GPS.
4. You can remove any POI file simply by removing it from your POI folder. and re-running the POI Loader software. This POI update procedure takes about 1-2 minutes.
In summary, keep your POI files updated on your PC and run POI Loader to update your GPS or SD card via any SD card reader.
Cheers
Feb 13, 2009 | Garmin nuvi 260W GPS Receiver
Hi i have had the lcx- 15 since 2001. i would like to update the software. plus the latest manual.
Here's the link to then manual => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Here's the link to software updates page => http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Here's the link to the most current software available from Lowrance =>
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-15-MT/Downloads/LCX-15-MT-Software-Update-310/
Please leave feedback. Thanks in advance.
Dec 07, 2008 | Lowrance LCX-15MT GPS Receiver
Where do I get free updates for my lowrance 500C gps?
you can go to this site and search for the specific update that you want
http://www.lowrance.com/Downloads/
in case you need any help in finding it here just post message
Sep 02, 2008 | Lowrance GPS
Lowrance 250c map update
http://www.lei-extras.com/store/search.asp?SearchType=Unit&Unit=iWAY+250C
You need to buy the Navteq map update, but you can call them and send in your memory card they will update it for a reduced cost, since 75 plus 12 shipping is too much just for maps, you can buy a whole new one.
Aug 14, 2008 | Lowrance iWAY 250C GPS Receiver
Lowrance Iway 500c GPS Receiver Logo
164 people viewed this question
Top Lowrance GPS Experts
Jay Plesset
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
