Question about Whirlpool RBS305PDS Electric Single Oven
Whirlpool Range GY396LXPB00
My keypad stopped working. We have had it replaced before, so we ordered another one, put it in and it still does not work. What could it be? It is not the lock button. We flipped the breaker and left it off for a few min. Any suggestions?
  • 1 more comment
  • shanco25 Jan 05, 2008
    My clock does display. It says PF then a time. It says PF because we flipped the breaker. Thanks for that information. Do you know what it could be since the clock does display?
  • shanco25 Jan 06, 2008
    Pushing the button doesn't fix it. We replaced the control panel. I checked all of the wires. There is a ribbon wire that attaches to it. Could it be that the front panel needs replacing?
    President:
  • 878 Answers
Shanco, is your clock working at all, does it display. If not, you have a thermal cut out on the back of that oven. This runs through the neutral side of that clock. If that TCO is open, the clock and display will not function. Part number 4451442. Very inexpensive. You can look it up at repairclinic.com for a price. They will have a picture of it. Now I'm going by model number gy396lxb00. You have to remove the back panelto get at it. According to the schematic Im looking at it looks to have 2 red wires going to it. Catriver
Posted on Jan 05, 2008
  • 1 more comment
  • Ron Marek
    Ron Marek Jan 05, 2008
    Aw man you messed me up with that rating. Anyway, if the display shows PF, press pause/cancel. Does the keypad work after that? You are not getting any error codes and this is a pretty basic oven control. After pressing pause cancel, hold it in for 5 seconds to see if you get any other error codes. My suggestion would be to go back and check all your connections on the new board. I see by the diagram that the keypad comes as a complete panel kit. #8191145 for white. When you installed the board, did you have to plug in a ribbon for the keypad or is it just an inlay? Let the cat know...Catriver.
  • Ron Marek
    Ron Marek Jan 06, 2008
    That's the only thing that's left. You already changed the main board. The keypad is not responsive. Do you have the owners manual? Just make sure there is no child lock-out for the keypad. That would be the only other thing. Thanks for changing the rating. The part number I listed for the panel is white. The last two digits will change: 46-bisq, 47-black, 48 stainless steel. So if your panel was stainless..part number would be 8191148. Catriver.
  • clrtadmud Jan 11, 2015
    I want this to read helpful what happened here?
6ya staff
SOURCE:
What is the eo f2 error code mean on a whirlpool oven
E0 F2 is a stuck key on the keypad. If your keypad is not available from the factory you may find a replacement unit here: http://www.fixyourboard.com/ledgestone.html
Aug 17, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
EO F2 whirlpool range
you have a bad keypad or a loose wire or ribbon,you can try unplugging it for 10 minutes and see if that helps or unplug it,remove the ribbon that connects to the keypad,plug the ribbon back in and see if that does anything,if not you need a new keypad. next time send the model number so i can help you betterF2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Range / Stove / Oven Fault Codes#ixzz1dikBsooc
Nov 14, 2011 | Whirlpool Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Error code E0 F2. Now oven will not come on, but stove above works.
F2
Jan 01, 2011 | Whirlpool RBS275PD Electric Single Oven
I have an accubake system electric oven and stove. When I tried to set the temperature on the oven the degree number kept rising to 500 degree on its own. Now it is displaying E0 F2 on the screen. Whats...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Aug 09, 2010 | Whirlpool RBS275PD Electric Single Oven
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Shows EO-F2-CODE
F2 means something is wrong with the keypad. Check that the keypad is firmly connected with the control board and press Cancel. If you get the code after a minute, replace the keypad.
Sep 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
E6, f2
You have a stuck or shorted keypad. Try Cancel/Off and hold for 10 seconds. Then push every key several times to unstick. If that does not work unplug range and remove the access panel, disconnect the wire connections, then replace them. If all these steps fail replace the control. good luck
Jun 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
WHIRLPOOL GY396LXPB00 MIGRATION CONTROL PROBLEM
press and hold at the same time child lock ( 2nd button in the row of buttons under the clock. and cancel ( bottom button far right ) hold until lock light blinks (10 -25 sec) hope it helps
Jun 11, 2008 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool RBS305PDS Electric Single Oven Logo
478 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
