Question about Bosch 24 in. SHU43 Built-in Dishwasher
Smelled like burning plastic
Ran washer it stop and smelled like it was burning. Can you check and how do you check the circuit board
I did this and will take it in today
Posted on Jan 07, 2008
  • 130 Answers
Ron, is this a dishwasher or clothes washer? If a dishwasher, check the wire nuts in the junction box. If there isn't a melted wire nut from a loose connection. Then you have to pull the outer door panel, then you can pull the control panel assy. This will require a t20 torx bit.
Posted on Jan 06, 2008
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Lg dishwasher smells like something is burning
This is an interesting problem and it requires some testing equipment to see what the problem is. You have to check the heating coil if it is a washer that heats the water. You also need to check the control board and some other things to see if you can locate the source of the burining smell. To perform these checks requite some test equipment like a meter.
May 22, 2013 | Dishwashers
Washer stopped spinning and something smelled like it was burning
immediately turn off your machine and check the power outlet if there is smoke, pull out plug, maybe there is a short circuit, do not plug again, call a handyman or bring to nearest service centers.
May 05, 2011 | Admiral 32 cu. ft. Washer
Washer stopped working all together
Hi,Check your water solenoid valve, the part where you connect (2) hoses, could be burnt out, sometimes they do, especially if your water pressure home (building) is low, or could be your motor, remove back of machine and check water valve, check valve with ohm tester, or visual check can tell you, if burnt out, replace it, few things could burnt out, motor, capacitor, switches/relay etc, but first check water intake (solenoid) valve, also,check / reset, fuse/circuit breaker, probably went of, when burning smell occurs, ( happened) if it's not your water intake valve, let me know, we can check other possibilities. but i believe it's your valve, good luck.
Aug 13, 2009 | Magic Chef CAV4000AWW Top Load Washer
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Circuit Breaker Kick and Washer Smell - Whirlpool Top Load
Welcome to FIXYA
sounds like you have a short in the wires and the burning smell is the wires burning from touching ...check the wires and look for any blackness anywhere or if you see smoke anywhere ....
my advice is see if you can find the short before pulgging it back in if not call a repair man could cause a fire
hope this helps you out have a good day:)
Jun 30, 2008 | Whirlpool LSB6200KQ Top Load Washer
Smelled like burnt board
reove screws holding on outer panel and unplug all the leads ( they are all coded so you cannot cross them ) open up plastic cover on module to reveal circuit boeard
Jan 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Electrical circuit Burning smell and fusing
very important !!!!!!! check the point of connection of this unit before next use
Jan 04, 2008 | AEG C41029G-M Dual Fuel (Electric and Gas)...
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
586 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
