NetGear RangeMax  WPN824 Wireless Router
Problem for NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
How to make my wireless network secure
By gray5170 on Nov 05, 2009
how to make my wireless network secure
Solution #1
posted on Nov 05, 2009
Not Rated)
bochard_20
Rank: Wiz
Rating: 81%, 123 votes
Hi! Buddy
You need to refer to the manual that came with your router for the exact steps, it depends what brand/model router you have.
Here are some tips what to change/not change:
1. Change the web-admin password of your router (even if it's wired this is good) so not anyone can get into the config page.
2. Change the default SSID (name) and don't use something that identifies you, your location, or your brand of router to outsiders (e.g. "Home", "Cox.net", "My Network", "Wireless", etc).
2. Enable WPA-PSK, WPA-PSK2, or if those aren't supported MINIMUM of WEP128. Refer to the manual or call the manufacturer for directions.
3. Don't hide the SSID. It just makes your life harder and it's easily found out anyways.
4. Don't bother with MAC filtering, if someone can crack your security they probably know how to spoof your MAC address which will circomvent the filtering.
5. Don't use static-IP, it just makes your life harder. Anyone with the slightest knowledge about networking knows how to use a static IP.
The reason you don't want to identify your router's brand/location/owner:
1. Default passwords and settings are available online. Knowing the brand makes it easier to bypass these.
2. Knowing where it is makes it easier to get a stronger signal while staying away. This gives the attacker an advantage of getting a strong signal and being hidden.
3. Knowing who owns it makes guessing your password easier. Most people use names, dates, and other personal info for passwords (bad practice) and if they know you they probably know the things you would use for a password.
I also like to put a piece of masking tape on top of the router and write the SSID and web-config password (maybe encryption key too) so I can't forget them if it's one I don't usually use, or if I'm setting it up for someone else so they can't misplace it. This doesn't bother me security-wise because if someone can get to the router, they can plug a wire in and use the network without knowing the wireless key...it's not as if I'm posting it for all the world to see.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Was this helpful?
Yes
No
Solution #2
Not Rated)
armstrng
Rank: Guru  Computer Networking  Expert
Rating: 86%, 72 votes
You will have to access the Netgear configuration panel by inputting the IP address or URL, that they gave you, into your browsers "address bar". Make sure to use ethernet cable attached to the router and PC, do not use wireless to setup the router web page.
Type in: http://www.routerlogin.net/basicsetting.htm
press enter
Username: admin
Password: password (both in lower case)
Press OK
The page should load. If it doesn't try powering down the modem and router. Power up the modem, then power up the router.
Once in the page set your security to WEP or WPA (not sure which one is on your device). After the security is set the router will reset itself and you will have to log in using your new code.
Hope this helps.
Was this helpful?
Yes
No
Solution #3
Not Rated)
sijudoniston
Rating: 86%, 46 votes
There are several kind of security provided in Netgear Router.
1. MAC access control list
2. WEP encryption
3. WPA-PSK
Enabling MAC access control and WEP encryption is enough for your home network.
Thanks
Siju.D
Was this helpful?
Yes
No
Popular Solutions for NetGear RangeMax WPN824
Questions and Unsolved Problems for NetGear RangeMax WPN824
Do you recommend NetGear RangeMax WPN824 Wireless Router (WPN824NAR)?
Answer
Answer
I have a rangemax router connecting my home desktop with windows xp to the internet. At random... (More)
Answer
had no problems with my wireless netgear router til I tried to install a wireless printer. Now... (More)
Answer
Must I buy Best Buy's $250 wireless router? Or is there another wireless router out there that's... (More)
Answer
Hi i had it working for 4 or 5 months then had a power failure. now it only works when cabled,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
