first make sure you have both taps on when you turn on the washer can you hear the water entering the machine if not you must decide if the fault is electrical or mechanical also if you do have water entering machine is it a good strong flow if not check filters or replace faulty valve good luck
Was this helpful?
Yes
No
Popular Solutions for GE WSXH208A Front Load Washer
I get an E39 Error code when I try to run a wash cycle and no water enters the tank. According to...
(More)
I get an E39 Error code when I try to run a wash cycle and no water enters the tank. According to documentation this suggests a dispenser problem. However, if I try t:12 dispenser test the tank fills fine and no error is recorded
It has a liguid softner container not drain or not used after full washing cycles are complete. It...
(More)
It has a liguid softner container not drain or not used after full washing cycles are complete. It has happened several times lately. I tis not working know. Please help. Thank you
when i put a load of clothes in. and it stops sometime their is 1 minute left on the washer. but it...
(More)
WHEN I PUT A LOAD OF CLOTHES IN. AND IT STOPS SOMETIME THEIR IS 1 MINUTE LEFT ON THE WASHER. BUT IT WILL NOT LET ME START THE OTHER LOAD. I HAVE TO LET IT SET FOR A WHILE THEN IT WILL START
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
