I have a kp-41s5 also knows as kp ef41, 41in. The convergence is bad. It jumps out of settings very often. How can I fix it? I read to check the solding..can you be more precise?
Is it possible to fix it by service menu?
I would like to change the whole convergence board, not only the ICs because I am inexpert, where can I find it?
The info on the link (below) is not specific to your model but should give you a good idea what's involved. Sometimes it's not economical to replace the board since the convergence part of the board only makes up 1/3 of the board. See link for more detail http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
do i need a code for to use it on my tv which is sony kp415su rear projection i have a durabrand...
(More)
do i need a code for to use it on my tv which is sony kp415su rear projection i have a durabrand remote dct1481
Originally came in with usual convergence issues, replaced the two STK chips, check/tested all was...
(More)
Originally came in with usual convergence issues, replaced the two STK chips, check/tested all was sweet. Customer brought back within days with horz sync issues, almost looks like something is breaking down. Sometimes has approx 10cm bands of sync tearing, is random. All SMPS rails are clean. Have searched for similar failures but can find no hits. Can you help? My email is john.wiersma@defence.gov.au
Hi I have a Sony KP-EF41 rear projection tv that does not turn on. When you switch it on the standby...
(More)
Hi I have a Sony KP-EF41 rear projection tv that does not turn on. When you switch it on the standby led flashes at about 1hz. I had a quick look and found the horizontal output transistor shorted. I replaced it and it shorted again. Any idea's? Is it worth repairing?
