here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View
NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
Remove the wire clip.
Disconnect the power outside rear view mirror electrical connector.
Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure.
Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in).
Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707)
Trim Cover
Removal
Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
Remove the two outside rear view mirror inside mounting hole cover screws.
Remove the outside rear view mirror mounting hole cover.
Installation
Mirror Control
Removal
Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
