Question about Toshiba Satellite A20 Satellite A25 Series Touch Pad - P000378380 CD-ROM Drive
Shutting down problem
Hi, I have my Toshiba A 200 continuously restarting every time I restart. The only method I can stop this is by removing the lead as soon as the computer swithches off. If I fail to do so the computer restarts automatically. It seems like the restart command has become default. Any help is much appreciated!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Go to setup utility and load the setup default values.
Also go to desktop properties and select screen saver tab and then at the bottom a power tab then go to advance tab and select when i press power button select option shut down.
Posted on Jan 07, 2008
6ya staff
SOURCE:
Toshiba satellite c55-b5201 won't shut down its stuck on shutting down but still hasn't and the battery light is flashing help i don't know what to do
Best to pres the power button for a few minutes to force shut down and restart.
If that doesn't work then remove power lead and pull the battery out and re-insert battery and power lead and restart.
Sep 16, 2014 | Computers & Internet
Hi, Today I was running my Toshiba Satellite C665 (OS Windows 7). I left my computer on when I needed to move away from it for an hour, and when I returned, my screen was showing the "blue screen of
method one:
restart computer and while pressing F8 and select "last known good configuration".
method two:
repeat same steps but select "safe mode". right click on Computer Icon- Properties- device manager- slide to sound,video and game controllers. remove your sound driver and restart then it automatically installs driver
Jun 02, 2017 | Computers & Internet
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
2004 ford f350diesle hard starting depress throtle nothing there
Dear dsmalley427,
I think it sounds like a fuel injection problem. You get fuel for a while until the injector backs up and then all of a sudden NO FUEL. The engine quits and the pressure drops and flow returns enough for you to restart. If I were you I would get to a good mechanic and check the fuel injectors.
OR--try adding a fuel additive that would clean the injectors.--Signed jwr
May 10, 2009 | 2004 Ford F350
Toshiba Satellite A205 unable to fully shut down
possible setting issue.
If you Go to,
start, control panel, power options, (classic view)
have a look in the power options there, set as needed. there is a few, check them all out.
use disc cleanup,defragmenter, delete temp internet files, in tools on menu bar , delete history,
update the Operating system at Microsoft.
update virus protection and run a full scan.
you should be good if no hardware problems.
Regards.
Apr 16, 2009 | Toshiba Satellite A205-S4639 Notebook
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Jan 25, 2009 | Toshiba Satellite A105 Notebook
Stuff shutting down
OK I WOULS SUGGEST RETURNING THE UNIT TO TOSHIBA OR CALLING THEM AT THIS LINK..http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp.THIS IS THE MOST ECONOMICAL WAY TO GO.RICHARDM69
Dec 29, 2008 | Toshiba Satellite (K000004080) Motherboard
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Ati2dvag caught in a loop
ati2dvag seems to have a problem with XP SP3
I don't know if you have SP3, but if you do, try rolling back to SP2
Method 1: Use the "Add or Remove Programs" item in Control Panel
1. Open the Control Panel
2. Select Add Remove Programs
3. Click to select the Show Updates check box.
4. Click Windows XP Service Pack 3, and then click Remove.
5. Click Finish to restart the computer after the removal process is complete.
Method 2: Use the hidden $NtServicePackUninstall$ folder
1. Click Start, click Run, type c:\windows\$NtServicePackUninstall$\spuninst\spuninst.exe in the Open box, and then click OK.
2. When the Windows XP Service Pack 3 Removal Wizard starts, click Next.
3. Follow the instructions on the screen to remove Windows XP SP3.
Method 3: Use the System Restore and select a restore point prior to SP3
Oct 05, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
