Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Rockfordsfostgate amp my amp have power but not putting out no more
  • tmck Jan 06, 2008
    yes the light is on my amp is on but its not pushing my speakers an yes i have one speaker blown do u no were i can send it off too be repaired
  • 631 Answers
Is the blue light lit?
Are any of the other lights lit?
Have you confirmed that the speaker isn't blown?
Posted on Jan 05, 2008
  • Perry Babin Jan 06, 2008
    Generally, if you want the woofer to be repaired to the original specs, you have to send it back to the manufacturer.
    Before you reconnect the speakers, you need to measure the DC voltage on the speaker terminals of the amp with the amp on but with no RCA cables plugged in. If the voltage is more than a fraction of a volt, the amplifier is in need of repair. Place the red meter lead in the positive speaker terminal and the black meter lead in the negative speaker terminal. Do this for both channels.
How can i unlock my tablet
Perform a factory reset instrutions in back of hand book.
Aug 23, 2014 | Tablets & eReaders
I brought a rover mgzr and want to put radio in it but the wires in the loom have had the connectors cut off so i just got the speaker wires and the four wires to power the radio, I know which speaker...
My assumption would be black = earth, red/black = power, purple power antena? green white? start by getting a test lamp put the earth ********, turn ignition on & check all wires for power also test in acc position & off position in case 1 is memory (constant power) once you know which ones are power put the test light in the power & black to check the black is the earth. Once you have + & - & speakers it should work.
Jun 27, 2012 | Cars & Trucks
Toshiba l 305d no power light, power suply ok.
The boards gone the same thing happend to me i wiggeled the power cable & it went off & never came on again i striped it down only to find that after testing it, the board had several chips poped witch stop the power lights form flashing,coz nomatter what the lights should allways react when power is put through them.
Just put it on ebay for spears i did & got £70 for it, better than putting in the bin.
Jun 17, 2010 | Toshiba Satellite L305D-S5904 Laptop
Screen is black, power button blinks from green to orange
Then something related with power supply is failed try taking the Memory Ram out & put it back in & also unplug all cables & press and hold power button for 10 sec & then put back all the cables and see
Jan 13, 2010 | Dell Computers & Internet
I got amp 4 chanel i fix power wires but it is not
every amp has this wires power in/usually. red color; ground/black ; amp. turns On/blue or blue/white, if you have more of this wires them this are for speakers input. (from your stereo system)
Jan 04, 2010 | Vehicle Parts & Accessories
My amp protection will not turn off i tryed almost everything?
i wish i can chat to you live so i can ask you qestions about your amp but to figure out what section of the amp might be fried it could be the power supply section could be the out put section or the in put section but i would try process of elimulation try unplugging your rca jacks and your subs unhook to your amp just the power hook up and try powering it but if the protection light steel comes on then try to remeber the last time your amp was working good and playing your subs was your amp getting hot if so you probaly fried your out put chips and not telling what else next question was you just hooking your amp up in your car and acually touch one of the power wire to the ground on your amp this happen to my friend and fried the power circuit relay chip on the power supply thats all the advice i can give but usually when the protection light comes on and you got every thing hook up right something fried
Oct 29, 2009 | Power Acoustik LT-980/2 Car Audio...
I get a pop from the sub when the power comes on.
This is caused because the stereo you have put in, is a high power output, or higher than the factory and puts that extra power into the factory amp systems causing the amp to surge the power to the speaker resulting in the pop sound,most newer cars use a stereo system without an internal amp so as to reduce heat and a external amp in usually under a seat or dash and a high power stereo boost the output of the amp.
Sep 27, 2009 | Car Audio & Video
Sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
May 27, 2009 | Sony XMD9001GTR Car Audio Amplifier
Orion 2400 mono
My esp light is blinking yellowish and the amp isn't putting out. I have power to it, just not putting power to my subs. anyone know how to help?
Feb 25, 2008 | Orion XTR Pro 2400 Car Audio Amplifier
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
131 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
